Seat swaps - Page 4 - Ford Truck Enthusiasts Forums
Seat swaps
  #46
Old 04-05-2014, 06:57 PM
adam22827 adam22827 is offline
adam22827 is starting off with a positive reputation.
oh ok, thanks.
  #47
Old 05-28-2014, 03:37 PM
wfilkins47 wfilkins47 is offline
wfilkins47 is starting off with a positive reputation.
Does anyone know if the transmission has anything to do with the fitment of the seats. I am planning on putting a 40/20/40 seat into my 93 supercab with Mazda 5 speed and want to make sure. Just from searching google, I cant find any pictures of a manual extended cab with a 40/20/40 seat in it, all with this combo seem to be straight cabs.
  #48
Old 05-28-2014, 03:43 PM
SteelHorse4x4's Avatar
SteelHorse4x4 SteelHorse4x4 is offline
SteelHorse4x4 is starting off with a positive reputation.
For the supercab you need the tracks and brackets from a bronco with the 40/20/40.
  #49
Old 05-28-2014, 05:57 PM
jacfordf-250's Avatar
jacfordf-250 jacfordf-250 is offline
jacfordf-250 is starting off with a positive reputation.
seats from 67 to 96 all inter change and so do all back windows
  #50
Old 05-28-2014, 06:05 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
WRONG!! Bronco NEVER came with a 40-20-40
wfilkins47, the transmission has Nothing to do with seat fitment. ONLY the cab does. You need the seat and brackets from a SUPERCAB. A reg cab and Crew cab are different
Quote:
WRONG again. Reg cab and crew cabs use the same bolt pattern(80-97)
But the front seat from a crew cab does NOT tilt forward, it needs to be modified to do so
Supercab is different
Bronco is different as well
  #51
Old 05-28-2014, 06:12 PM
BRAD. EXCUSE THE @%*$ out of me. Yes, seat tracks from a Bronco and the "center bracket" from a supercab. OMG. A MISTAKE. No wonder everyone thinks....................... Not Worth It.
Sorry, bad day and not a lot of tolerance left for......................
  #52
Old 05-28-2014, 09:00 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is online now
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
BRAD. EXCUSE THE @%*$ out of me. Yes, seat tracks from a Bronco and the "center bracket" from a supercab. OMG. A MISTAKE. No wonder everyone thinks....................... Not Worth It. Sorry, bad day and not a lot of tolerance left for......................
Seems to me you were partially right. Are seat it self will fit they all have the same 4bolt size that bolts then to the rails. It's the rails that vary along with the tilt on the seats crew cab doesn't tilt as brad said
Hell even seats out of the explorers/rangers will bolt to the f150 seat rails
  #53
Old 05-28-2014, 11:16 PM
Truck Guy99's Avatar
Truck Guy99 Truck Guy99 is offline
Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.
Quote:
Originally Posted by heartlandcowboy90 View Post
im thinking im going to put a 40/20/40 seat out of a dodge pickup into my 90......may have to drill some holes and put a space or two in but i think it should work out....i hate not having an arm rest and no cup holders, plus my bench is worn out bad
I've thought about doing the same swap in my 88 with a 94-98 dodge full size truck split bench. We used to have a truck with these in it and it was very comfy. It's just hard to find a truck this body style with the red interior I need so it'll match my trucks interior.
Has anyone ever done this?
  #54
Old 05-29-2014, 12:51 PM
Thats what I thought, although its weird I cant find an extended cab manual with the 40/20/40, thought maybe the floor pan was different.
On another note, for anyone that has mounted the "separately tracked" supercab seats, is there an indent or something in the floor pan which indicates where the holes should be drilled to mount them? Thanks again for everyone's help.
  #55
Old 05-29-2014, 12:59 PM
Quote:
Originally Posted by wfilkins47 View Post
Thats what I thought, although its weird I cant find an extended cab manual with the 40/20/40, thought maybe the floor pan was different. On another note, for anyone that has mounted the "separately tracked" supercab seats, is there an indent or something in the floor pan which indicates where the holes should be drilled to mount them? Thanks again for everyone's help.
Only difference in the tranny hump is the hole for the shifter and the hump it typically bolted to the floor to allow access to top of tranny where a. Auto the floor is solid Seats are same in auto/manual
For the holes bolt the outside in and then drill the passenger and bolt in
  #56
Old 05-29-2014, 02:45 PM
Finger__Rachet's Avatar
Finger__Rachet Finger__Rachet is offline
Finger__Rachet is starting off with a positive reputation.
Quote:
Originally Posted by Midnite1987 View Post
i just swapped in a set of explorer seats to my 40 20 40 seats. just swapped the seats and used the same frame rails from my truck. they bolt right in. dont have pic in truck as its dark here now.
I have an 88 Supercab with bucket seats from the factory. Could I do the same as you did, get newer Expedition buckets and replace mine?
  #57
Old 05-29-2014, 04:15 PM
Quote:
I'm not sure how new you could go but up to 97 before the body style changed should bolt right in. Not sure about newer then that tho
Here's the 96 explorer seats in my old 96 f150
  #58
Old 05-29-2014, 04:25 PM
I built a frame from 1.25" angle and mounted to the bench ceat slider in an old gmc I had and mounted a set of seats from a 78 bronco and built a console and mijnted betwee. The seats to the frame. Whole thing still slid like a bench but I always had it all the way back
If you have right tools can make anything fit
  #59
Old 05-29-2014, 04:40 PM
wfilkins47
There's a special bracket that the 20 seat mounts to. It actually goes from the inside bolts for the 40 seats and the 20 section mounts to it.
  #60
Old 05-30-2014, 12:48 PM
wfilkins47
Ok, thanks for your help.
King Ranch Seat Swap? Windy Isle 1997 - 2003 F150 2 10-28-2016 11:30 AM
Bench to Bucket seat swap?? firegod75 1987 - 1996 F150 & Larger F-Series Trucks 3 12-28-2015 11:22 PM
Retrofit seats NativeDescent 1987 - 1996 F150 & Larger F-Series Trucks 3 08-10-2015 08:37 AM
Engine Swap 89_Bronco_lover 1978 - 1996 Big Bronco 4 05-06-2015 05:14 PM
Added power seats to STX ChrisAdams 2004 - 2008 F150 2 01-28-2005 09:56 PM
Tags
1985, 1989, 1993, bed, bench, console, efi, f150, f350, fold, ford, seat, short, stock, swap, swaps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
