Seat swaps
Old 09-04-2012, 10:13 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
I took captains chairs and a console from a bronco and just drilled holes in the floor and used washers for shims.
  #32
Old 09-04-2012, 10:24 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
What I am worried about is the nuts rattling off going down the back roads. Could we weld it some how.
Trav
  #33
Old 09-05-2012, 12:24 AM
nighthawk285's Avatar
nighthawk285
nighthawk285 is offline
If you're handy with a drill and/or welder, you can make anything fit !! I took the 40/20/40 seats from a '96 Supercab, and fitted em into my '87 Reg cab that had a standard bench. And when it was all said and done, it's a whole bolt in assembly that didn't require any drilling into the floorboards!
Before
During....drilled all the spotwelds out of the one-piece frame
Welded the "feet" from the original bracket to the new one-piece
And bolted in.....this is an old picture, and believe me the carpet was cleaned the next day!
  #34
Old 09-05-2012, 12:30 AM
Redneckfordf2502002
Cool will keep that in mind for when we get to it. Thanks for the info nighthawk285.
Trav
  #35
Old 09-05-2012, 12:43 AM
nighthawk285
No prob! Two years of hard use later and I haven't had any problems with bolts rattling loose or anything.
  #36
Old 09-05-2012, 05:03 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
that seat pan was from a reg cab/crew cab
  #37
Old 09-05-2012, 09:27 AM
nighthawk285
Oops! Yeah I did forget to mention that, that pan came out of a '91 crew cab, the brackets that were on the seats to start with were all so they could bolt in individualy if I remember right
  #38
Old 09-05-2012, 12:35 PM
Redneckfordf2502002
I looked at it today and the drivers fits fine I just need to drill a couple of holes in the floorboard and bolt it down but the passnger is the one that is giving me troubles unless I cut that bolt that sticks up and drill holes then bolt it down. I wasn't going to bolt down the console because the thing has a strap on it that I can carry it with me. Now all I need is some time and our cordless and the bolts fromt the last truck and find some nuts laying around get some lock washers and that truck will be good. I can't wait to drive this truck again it was so fun driving it the first time we bought it but then we didn't pay attention to it and problems happened but now all good as new.
Trav
  #39
Old 09-05-2012, 02:13 PM
Diesel_Brad
Yes and the supercab rails make the seat sit higher on a reg cab/crew cab seat pan
  #40
Old 09-05-2012, 02:31 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
Trav
When I put mine in, I tack welded washers to the floor board underneath, so that the floor is reinforced (an idea that was given on this site) I also welded the nuts underneath to the washers so that they wouldnt just come off. Once in a while I check the whole truck over to see if anythings loose or missing and haven't had an issue since I put mine in.
  #41
Old 09-06-2012, 05:00 AM
Diesel_Brad
No need to weld anything. Tighten the nuts to proper torque, and if that is not enough for you, use lock nuts
  #42
Old 09-06-2012, 10:36 AM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
One reason I did it was so that I didn't need 2 people to tighten them down.
  #43
Old 09-06-2012, 11:26 AM
Redneckfordf2502002
Me and my dad looked at it last night and he said he is going to drill holes in the cab and use lock washers and nuts and bolt the thing down and then we will be ok. I have had running boards with lock washers and nuts and they haven't rattled loose on I am constantly stepping into our 02 F250 (what the running boards are on.)
Trav
  #44
Old 04-05-2014, 05:23 PM
adam22827's Avatar
adam22827
adam22827 is offline
2000 f250 super duty
So, what kinda seat could I replace my bench seat with? I have a 2000 f250 super duty regular cab. leather or cloth doesn't concern me, just want a direct bolt in if possible,thanks.
  #45
Old 04-05-2014, 05:46 PM
maverick1701's Avatar
maverick1701
maverick1701 is offline
I think all SD seats are swap-able but I am not 100% positive. You might be able to get more concrete answers in the super-duty section. This area is mostly OBS rigs up to 1997.
Quick Reply: Seat swaps
