Seat swaps - Page 3 - Ford Truck Enthusiasts Forums
Seat swaps
  #31
Old 09-04-2012, 11:13 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
I took captains chairs and a console from a bronco and just drilled holes in the floor and used washers for shims.
  #32
Old 09-04-2012, 11:24 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
What I am worried about is the nuts rattling off going down the back roads. Could we weld it some how.
Trav
  #33
Old 09-05-2012, 01:24 AM
nighthawk285's Avatar
nighthawk285 nighthawk285 is offline
nighthawk285 has a very good reputation on FTE.nighthawk285 has a very good reputation on FTE.nighthawk285 has a very good reputation on FTE.
If you're handy with a drill and/or welder, you can make anything fit !! I took the 40/20/40 seats from a '96 Supercab, and fitted em into my '87 Reg cab that had a standard bench. And when it was all said and done, it's a whole bolt in assembly that didn't require any drilling into the floorboards!
Before
During....drilled all the spotwelds out of the one-piece frame
Welded the "feet" from the original bracket to the new one-piece
And bolted in.....this is an old picture, and believe me the carpet was cleaned the next day!
  #34
Old 09-05-2012, 01:30 AM
Cool will keep that in mind for when we get to it. Thanks for the info nighthawk285.
Trav
  #35
Old 09-05-2012, 01:43 AM
No prob! Two years of hard use later and I haven't had any problems with bolts rattling loose or anything.
  #36
Old 09-05-2012, 06:03 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
that seat pan was from a reg cab/crew cab
  #37
Old 09-05-2012, 10:27 AM
Oops! Yeah I did forget to mention that, that pan came out of a '91 crew cab, the brackets that were on the seats to start with were all so they could bolt in individualy if I remember right
  #38
Old 09-05-2012, 01:35 PM
I looked at it today and the drivers fits fine I just need to drill a couple of holes in the floorboard and bolt it down but the passnger is the one that is giving me troubles unless I cut that bolt that sticks up and drill holes then bolt it down. I wasn't going to bolt down the console because the thing has a strap on it that I can carry it with me. Now all I need is some time and our cordless and the bolts fromt the last truck and find some nuts laying around get some lock washers and that truck will be good. I can't wait to drive this truck again it was so fun driving it the first time we bought it but then we didn't pay attention to it and problems happened but now all good as new.
Trav
  #39
Old 09-05-2012, 03:13 PM
Yes and the supercab rails make the seat sit higher on a reg cab/crew cab seat pan
  #40
Old 09-05-2012, 03:31 PM
GNR22's Avatar
Quote:
Trav
When I put mine in, I tack welded washers to the floor board underneath, so that the floor is reinforced (an idea that was given on this site) I also welded the nuts underneath to the washers so that they wouldnt just come off. Once in a while I check the whole truck over to see if anythings loose or missing and haven't had an issue since I put mine in.
  #41
Old 09-06-2012, 06:00 AM
No need to weld anything. Tighten the nuts to proper torque, and if that is not enough for you, use lock nuts
  #42
Old 09-06-2012, 11:36 AM
GNR22's Avatar
One reason I did it was so that I didn't need 2 people to tighten them down.
  #43
Old 09-06-2012, 12:26 PM
Me and my dad looked at it last night and he said he is going to drill holes in the cab and use lock washers and nuts and bolt the thing down and then we will be ok. I have had running boards with lock washers and nuts and they haven't rattled loose on I am constantly stepping into our 02 F250 (what the running boards are on.)
Trav
  #44
Old 04-05-2014, 06:23 PM
adam22827 adam22827 is offline
adam22827 is starting off with a positive reputation.
2000 f250 super duty
So, what kinda seat could I replace my bench seat with? I have a 2000 f250 super duty regular cab. leather or cloth doesn't concern me, just want a direct bolt in if possible,thanks.
  #45
Old 04-05-2014, 06:46 PM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 has a good reputation on FTE.maverick1701 has a good reputation on FTE.
Quote:
I think all SD seats are swap-able but I am not 100% positive. You might be able to get more concrete answers in the super-duty section. This area is mostly OBS rigs up to 1997.
Bench to Bucket seat swap?? firegod75 1987 - 1996 F150 & Larger F-Series Trucks 3 12-28-2015 11:22 PM
Retrofit seats NativeDescent 1987 - 1996 F150 & Larger F-Series Trucks 3 08-10-2015 08:37 AM
Child seats and supercabs Buck268 2009 - 2014 F150 3 08-19-2014 04:27 PM
Bucket to bench seat swap roughridn_sob 1987 - 1996 F150 & Larger F-Series Trucks 6 03-28-2014 03:51 PM
Bronco seats won't fit? lgwilson 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 06-27-2010 12:40 PM
Tags
1985, 1989, 1993, bed, bench, console, efi, f150, f350, fold, ford, seat, short, stock, swap, swaps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
