Seat swaps - Page 2 - Ford Truck Enthusiasts Forums
Seat swaps
Old 03-04-2012, 10:38 PM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 has a good reputation on FTE.maverick1701 has a good reputation on FTE.
Quote:
Originally Posted by IDIDieselJohn View Post
If you have a reg. cab or crew cab, all benchs are interchangeable.
Super cabs are unique.
Putting buckets in a bench seat truck is not a bolt in deal.
its hella easier to swap in a 40/20/40 and replace the jump seat with a console...much much easier than having to drill new holes in floor, fab mounts etc.
Old 03-05-2012, 07:35 AM
deljac's Avatar
deljac deljac is offline
deljac is gaining momentum as a positive member of FTE.deljac is gaining momentum as a positive member of FTE.
the bench seats whether from a supercab, reg cab or a crew cab all have the same mounting it is a direct bolt in. within the last months ive installed 2 bench seats with the fold down center from reg cabs into a 92 and a 93 both supercabs. and one of the seats was from a 87 reg cab and the other was from a 93 reg cab
Old 03-05-2012, 09:32 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
I bought a set of buckets, with the console...I have them in, but needing to finish up....Haven't had the time, with the past 2 wks...
They're manual seats, with the electric lumbar....
Only thing they didn't come with was the spacer for the console, which is fine....I can make my own..
Old 03-05-2012, 04:17 PM
cwbright cwbright is offline
cwbright is starting off with a positive reputation.
Leather 40/20/40 out of an 03 Lariat. I had to fabricate a new rail to go under the seats, but they're so nice.
Old 09-02-2012, 01:24 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
Quote:
Sorry as I'm being thick headed and still a little fuzzy on this. So, in my crew cab, I could mount my existing 40/20/40 front seat in place of the rear seat, and mount a 40/20/40 from the front of an extended cab or Bronco as my front seat? With no holes needing to be drilled?
Old 09-02-2012, 01:31 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
So, in my crew cab, I could mount my existing 40/20/40 front seat in place of the rear seat, YES
NO
SUpercab 40-20-40 seats have a 3 piece frame(one for each part of the seat)
Reg cab and crew cabs have a 1 piece frame(all 3 seat pieces bolt to it) and then it bolts in like a bench
Old 09-02-2012, 08:28 PM
LeoJr's Avatar
Quote:
Originally Posted by Diesel_Brad View Post
NO
A clear answer and an explanation! Thanks!
Old 09-02-2012, 09:09 PM
norfolknova norfolknova is offline
norfolknova is gaining momentum as a positive member of FTE.
I was given a set of seats out of either a navigator or a top end expidetion. It is going to require a bit of fabrication. I am going out for surgery end of September and will be out for 6 to 8 weeks, so i fugure I will have some time on my hands then to mess with them. The are a bit wider than my 92 seats and i may need to find a skinnier console to make them fit.
I will have a thread documenting the swap
matt
Old 09-02-2012, 10:35 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
thats a nice fit.must be from an 03 f150? im not a fan of the over stuffed '99+ super duty seat fitment.that's a much more correct fit for our sized cabs.
now to see if those come in black.
how do they ride? or let me ask this,softer,equal to,or firmer than 92-97 buckets?
Old 09-02-2012, 11:07 PM
Yes, they're out of a 150. They ride really nice, in fact, they're probably the reason I haven't gotten rid of the truck with all the problems I've had lately. The actual firmness is about the same, but my truck originally had a bench seat, so the ride is much better. My daily driver is a little VW golf, so having a seat with a bit more shape to it fits my driving style a lot better - I don't go sliding around quite so much. I think this is pretty much the best option for a swap into a truck of this year - it's comfy, I can still fit 3 passengers if I need to, and I get cup holders!
Old 09-03-2012, 01:53 AM
Midnite1987's Avatar
Midnite1987 Midnite1987 is online now
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
i just swapped in a set of explorer seats to my 40 20 40 seats. just swapped the seats and used the same frame rails from my truck. they bolt right in. dont have pic in truck as its dark here now.
Old 09-04-2012, 05:09 PM
heartlandcowboy90 heartlandcowboy90 is offline
heartlandcowboy90 is starting off with a positive reputation.
im thinking im going to put a 40/20/40 seat out of a dodge pickup into my 90......may have to drill some holes and put a space or two in but i think it should work out....i hate not having an arm rest and no cup holders, plus my bench is worn out bad
  #28
Old 09-04-2012, 07:40 PM
LeoJr's Avatar
So I find me a non-extended cab front seat frame and I can bolt all of these seats to them, in the front of a regular cab or the rear of a crew cab?
  #29
Old 09-04-2012, 07:57 PM
Just a FYI. That is NOT a 40-20-40. That Is a 40-60
  #30
Old 09-04-2012, 08:33 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is online now
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
hey guys this is a little off topic I think but I have to ask this and it is alot easier to ask here where others have done it then open a thread and be directed here. So here it goes. I bought seats out of a 85 Ford super cab F250 captain chairs and a middle console. Well I am putting them in our 89 F250 4x4 regular cab. Well I figured out how I am going to put the console in but how can I put the seats in. The 89 F250 had a bench seat. I think I would have to fab up some mounts but biggest question is does anybody have some made up I can kinda figure out how to make them up?
Trav
King Ranch Seat Swap? Windy Isle 1997 - 2003 F150 2 10-28-2016 10:30 AM
Bench to Bucket seat swap?? firegod75 1987 - 1996 F150 & Larger F-Series Trucks 3 12-28-2015 10:22 PM
Retrofit seats NativeDescent 1987 - 1996 F150 & Larger F-Series Trucks 3 08-10-2015 07:37 AM
Engine Swap 89_Bronco_lover 1978 - 1996 Big Bronco 4 05-06-2015 04:14 PM
Bronco seats won't fit? lgwilson 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 06-27-2010 11:40 AM
Tags
1985, 1989, 1993, bed, bench, console, efi, f150, f350, fold, ford, seat, short, stock, swap, swaps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
