Charging system??? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Charging system???
Old 01-31-2012, 12:48 AM
Mike Cavalier Mike Cavalier is offline
Mike Cavalier is starting off with a positive reputation.
Charging system???
so the truck is a 01 f-350 srw lariat, it has the ambulance package-dual alternator package...can someone tell me why there would be two alternators on this truck instead of a good decent sized one, like any other diesel?? i noticed a few weeks ago while driving stopped at idle my trucks voltage was only at 12.1v, driving over 1000rpm it was normal about 14.3v, under load “lights and blower motor on” while driving 1800rpm i only had 13.4v when prior i would maintain 14.2-14.3v idle or high idle....full field testing of the charging system "110a alternators” primary pulled 30a and secondary pulled 8a, after the test system V was 11.9v...lights are dimming ect ect....i tested the batteries statically and in parrel, full field test was done with a VAT machine and a snapon detect, testing result bad diode in alternator, voltage ripple 385mV high idle....voltage drop across entire starter system and alternators test was 0.3v spec is 0.5v...would a bad diode cause my problem? i hear no wine or radio static ect....if one alternator is bad why isn’t the other one helping me out here??
thanks, mike
Old 01-31-2012, 11:35 AM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
Dual alternators provide more amperage than a single alternator. With the ambulance package, it was designed to have a greater current load on the system.
Yes a diode can cause problems like this. They can cause all kinds of issues with t he electrical system. You need to swap out the bad one and you will be set.
Old 01-31-2012, 02:12 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
Agree with Woodnthings on this - replace/test both alts. and then re-test and see how your voltage stands.
Old 02-01-2012, 11:06 PM
thanks for the reply’s guys...i figured that, just couldn’t figure buying two new alternators right now, but you gotta do what you gotta do...just the dual alternator set up........im a diesel mechanic and rigs that pull massive amounts of amperage 12v or 24v systems trucks or busses for the most part have one massive alternator....like or 92 f-custom 7.3L its or rescue truck at the firehouse, lights, sirens, generators, hurst tools, ect. ect....or even internationals TT444E the 7.3 in international MD trucks has one big alternator....just doesn’t make sense
Old 02-01-2012, 11:17 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
I've often wondered why go with two alternators when a single large one could handle the load. Best I can figure is that maybe the E series have a hood clearance issue or more likely...the ambulance industry wants a secondary alternator as a back up just in case. When a patient's life depends on the ambulance getting to the hospital then redundant systems makes sense.
Just supposing though...I really don't know why Ford went with the duals either.
Old 02-03-2012, 11:38 PM
okay so i got the scoop today on the dual alternator set up...im a student at UTI and i talked to the ford fact teacher who claims to have specialized in the 7.3L for many years, he said both alternators work together at the same time, if one is bad, or if you disconnect the one, it will draw off of just one, since its trying to draw off of two, and its only drawing off of one, it full fields the alternator frying diodes, such as in my case. the idiot light doesn’t come on because its still charging a slight amount...ford did this because its cheaper then the 290a alternators they used in the newer “ambulance package” that alternator is $700, and it requires more room...basically ford did this to save money, i was advised to replace both of them...
Another glorious ALT/GEN Battery light Question Flexxj90 6.4L Power Stroke Diesel 0 02-16-2016 01:23 PM
Alternator charge question 6.0PSD ATV PRO #11 Electrical Systems/Wiring 1 09-09-2015 03:12 PM
Electrical System-Voltage and Charging Problem Farmboy1539 1994.5 - 1997 7.3L Power Stroke Diesel 11 07-31-2015 02:13 PM
Burning through 3G alternators - Help! guisepi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 07-20-2015 01:44 AM
Charging Issues jrodjared 1999 - 2003 7.3L Power Stroke Diesel 8 05-23-2015 09:45 PM
Tags
2001, 2003, 54, 700, 73, 96, ambulance, charging, diesel, f350, ford, problems, system, systems, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
