Lokar Bracket ????
Lokar Bracket ????
Will this Bracket work with the stock throttle cable or do i need to purchase a aftermarket cable??
Lokar SRK-4000 - Lokar Throttle Cable Brackets - Overview - SummitRacing.com
I have the Offy DP and used the 4' Lokar cable...they can be shortened. Hook up is a breeze running the cable around the front to the rear of the carb pulling from the fender side. When I used the Spectre bracket, clearance with the heater box was a problem. The Lokar bracket's different configuration took care of that.
Here's the link to the throttle cable that i used.
Lokar TC-1000HT48 - Lokar Throttle Cables - Overview - SummitRacing.com
aunchman
20
09-05-2002 02:39 PM
