Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Sign in using an external account
Register Forgot Password?
  #16 (permalink)
Old 02-06-2012, 09:04 PM
raytasch raytasch is offline
1956 Ford F-350
My Garage
raytasch is gaining momentum as a positive member of FTE.raytasch is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by jjurva View Post
Im relatively new to working with carbs. How bad can I screw things up while installing a kit?
Bad......... Seriously, parts can get lost, go flying into never never land, parts can get installed wrong and the list goes on. Like 46Yblock said above.
Now, if you have good mechanical skills, a place to work, tools and not easily intimidated, get a kit and carb cleaner and go for it. Tip, take detail pictures and understand the different fuel delivery systems in the carb and how they work.
__________________
Fords in the Stable
1956 F350 DRW with hydraulic dump
2007 F150 supercab
1973 F250 Camper Special
1955 Ford 850 restored
  #17 (permalink)
Old 02-07-2012, 12:06 PM
ALL AMERICAN BOY's Avatar
ALL AMERICAN BOY ALL AMERICAN BOY is offline
Garage is empty, add now
ALL AMERICAN BOY is starting off with a positive reputation.
jj
could you be a little 'wordier' in your posts?
nobody is going to 'jump on you'.
you seem to keep homing back to carburetor.
did you plug up all vacuum lines to it?
yes, i think you can rebuild it yourself.
can you build a model kit?
do you build R/C cars?
is so rebuilding this carb is easier.
once it's clean you can do it on kitchen table.
yes do keep track of parts.
would your computer work if you left out hard drive?
same thing.
Have A Nice Day!
  #18 (permalink)
Old 02-07-2012, 09:28 PM
jjurva jjurva is offline
jjurva is starting off with a positive reputation.
I may as well give it a try. If it doesn't go well I will pay someone to do it for me. I mean the worst that will come of this endeavor is me wasting 20 bucks on a rebuild kit. Thanks everyone.
  #19 (permalink)
Old 02-07-2012, 10:19 PM
jj
remember to get the $20 can of
Mac's carburetor cleaner while you're
at NAPA.
standy by and i'll edit in napa carb kit #
that fit's mine and most autolite 2 bbl's.
#25585.
Have A Nice Day!
Tags
272, 302, block, choke, choked, closed, engine, ford, idle, run, start, truck, trucks, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
