trucks wrench light came on again
on my 04 f350 wrench ilght came on again it has been on for a while .did a oil change and added 2 rev x for a cold start run rught light went out after oil change ran good 2 days .this am 3 mi from start light came on and gauges in dash swong over and came back truck runs fine.thanks.
Go to an autoparts store they will usually scan it for free
Way to many things to guess at
but does sound like your having ruff cold starts am I on track here if so then the FICM Volts needs to be checked
So check your ficm volts
https://www.ford-trucks.com/forums/8...procedure.html
here^^^^^^^^^^^^^^^
check that and code scan it you cant let this 6.0 go things can get spendy FAST with multiple failures
here^^^^^^^^^^^^^^^
This bad battery may have taken out your ficm had to say untill you test it and I suggest that you do it soon before it starts dropping injectors too!!!
also test the Alternator make shure its ok too
This electrical stuff can take Multiple things out if one thing goes bad and you push it
When that battery light comes on its best to get right on it before you get multiple failures
