Boss 429?
Boss 429?
I am trying to replace a water pump on what I thought was a 460 in a 75 F-250. New water pump did not line up, doing a search with the casting numbers on the original pump (C8SE 8505-E) I found out the pump belongs to a 429 Boss. I know the 429 and 460 block are the same, but I have just bought a cam and headers for the same rig and don’t know if I should change anything or not. The only thing I know for sure about this motor is it’s not the original block for this truck. Are the Boss heads or block special, and what numbers am I looking for to see if it’s more than just the water pump that is a Boss? This one has kind of thrown me for a loop, any advice would be appreciated.
If your spark plug wires go into the center of your aluminum valve covers you should get excited .
The one and only time I have ever even seen one of these motors up close was at a Ford booth at an auto show back in 1985:
http://upload.wikimedia.org/wikipedi...x-Boss_429.jpg
For purposes of thinking pure thoughts, I try to pretend that such an engine never even actually existed!
And yes both the blocks and heads are special as well as the pistons, intake, rockers etc.
Thank you, I appreciate the help. Plug wires are normal, nothing going through the valve covers. guess previous owner went with a Boss water pump, don’t know if that is an advantage. I guess my only other hope is this would be a Boss block? Any difference or easy way to tell the difference? Once again, i appreciate the help, i am a Ford big block rookie!!!
If it doesn't have Boss heads on it, then it's almost assuredly NOT a boss block.
The thing is that is NOT a boss water pump, it just happens to be a water pump that has the same casting number as the one used on Boss motors. For it to be a "boss water pump" then the Boss 429 would have to be the ONLY application for it. That water pump if you note has a C8 casting number indicating a 1968 revision date, the Boss 429 didn't come out until 1969, thus it was being used on engines prior to the introduction of the Boss.
Vee
03-10-2006 02:43 PM
MR_J_DAHMER
02-01-2006 01:47 AM
