What does advance timing mean?
By the distributor is a grey connector called the spout. By unplugging that the computer stops controlling the timing. Then you can rotate the distributor and reset the timing.
Using a timing light you mark the balancer at 12 or 14 degrees then turn dist until the mark ligns up with your mark. Then you tighten up dist and plug in spout and your done. Keep reading on here. You'll find pics and better write up for sure.
It's the ignition timing, which is the number of degrees of crankshaft rotation before the piston is all the way at the top (called top dead center or TDC) at which the spark plug fires.
On your truck (assuming it's the 1989 in your profile), it is adjusted using a timing light and by loosening the clamp at the base of the distributor, and then slightly rotating the distributor. There is a connector jumper (called SPROUT) that needs to be removed before checking the "base" timing.
Here's a good link:
Fuel Injection Technical Library » Setting the timing
Now, if your truck is anything like mine, the distributor may be frozen in place, you can search on that as well and read all about it too.
Here's a good link:
turnkyle
08-12-2012 08:44 AM
iwals
11-21-2010 10:52 AM
GSchretter
10-06-2004 02:06 PM
VintageBlueOval
05-05-2004 10:47 PM
