88 trailer brake controller
Old 01-30-2012, 01:48 PM
Country_boy_2007's Avatar
Country_boy_2007
Country_boy_2007 is offline
So im pretty sure the brake controller in my 88 250 has taken a poo on me. What are you guys running on your trucks?
Old 01-30-2012, 02:51 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
i had an old uhaul controller in the 88 till it died a few years ago.
i took it out and was going to replace it but never got around to it.
Old 01-30-2012, 06:07 PM
Coalroller's Avatar
Coalroller
Coalroller is offline
I love my activator III! but if it ever goes out im gonna get the true control brake controller! We have one on our company truck and man is it nice!
Old 01-30-2012, 06:17 PM
Crazy2's Avatar
Crazy2
Crazy2 is offline
I run Prodigy P3 i wouldn't run anything diff with the wgt i pull
Old 01-30-2012, 06:35 PM
bashby's Avatar
bashby
bashby is offline
Prodigy is a really good product, but expensive. Get one unless its too much $ for you. I think there is a P2 and P3 depending on application but not sure of the difference, maybe someone else knows more.
Old 01-30-2012, 06:50 PM
Coalroller's Avatar
Coalroller
usually the difference between the 2 and 3 on most break controllers is the amount of axles it can handle for breaking.
Old 01-30-2012, 07:07 PM
Crazy2's Avatar
Crazy2
Crazy2 is offline
P3 is updated Prodigy the P2 they found problems with them
Old 01-30-2012, 07:42 PM
swimnshoot's Avatar
swimnshoot
swimnshoot is offline
My truck came with one, it's the first one I've ever owned so I don't know too much about it. I traced the wires and know the ground is disconnected and the in-line fuse/relay looks toast.
My boat trailer, 8,000 lbs total, has a hydraulic actuated tongue to disk braking system. So, I guess the El. brakes won't work for me anyways ?
Old 01-30-2012, 08:07 PM
tjc transport
i ain't rite
that is called a surge brake system.
you do not need an electric brake controller with that system
Old 01-30-2012, 08:33 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
My motorhome has the OLD dinosaur era hydraulic/electric brake controller, with a steel brake line running through the firewall, from a T on the master cylinder.
Old 01-30-2012, 10:07 PM
bashby's Avatar
bashby
bashby is offline
Thats what I thought
could be right... do a little research if you decide on the prodigy. I've got the lower cost one from tekonsha (they make the prodigy), I think the one I have is the voyager... it works good. There are 2 types, one like I had in my 98 cherokee years ago, applies the brakes the same amount wether you Are braking lightly or in a panic stop... that system sucks. Just touch the brake pedal enough to turn on the brake lights and the trailer brakes apply full force. The better systems sense how fast the tow vehicle is braking and apply the trailer brakes accordingly.
Old 01-30-2012, 10:11 PM
bashby's Avatar
bashby
bashby is offline
As I recall, those worked pretty good. I think thy got phased out because of the possibility of brake fluid leaks.
Old 01-30-2012, 10:13 PM
tecgod13's Avatar
tecgod13
tecgod13 is online now
I put a Tekonsha Voyager into my Ranger when I started towing with it. Moved it to the F250 when I bought the truck. I believe its the precursor to the Prodigy (same company). Never had any problems with it.
Go down to the towing forum, theres a lot of people on there with tons of experience with the different controllers on the market.
Old 01-30-2012, 11:55 PM
Country_boy_2007
lol thats the same exact one that i have. it may just have a wireing issue, i havent looked too closely into it yet.
Old 01-31-2012, 02:15 AM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
I have the model after Johns, was in the 84, works great, I never had problems with it.
Quick Reply: 88 trailer brake controller
