Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 01-30-2012, 02:56 AM
Goob Goob is offline
Garage is empty, add now
Goob is starting off with a positive reputation.
Lightning oil cooler
MY question is on a 1993 351 Windsor lightning motor can I turn the way the oil cooler sits around ? it bolts on the oil filter outlet and has two ports for the water to run through but it won't fit rite unless I turn it all facing the back of the motor. I don't think this will cause a problem but just wanna be sure thanks for any help!!!!
  #2 (permalink)
Old 01-30-2012, 08:57 PM
Blurry94's Avatar
Blurry94 Blurry94 is online now
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
As long as you extend the coolant lines then it shouldn't be an issue. Otherwise, you can remove the oil cooler, install a one piece lower radiator hose from an earlier F-series (like a 1990) and run an FL-1A oil filter instead of the FL-820s.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
Tags
1993, 351, 351w, 54, 94, cooled, cooler, delete, engine, ford, fordlightning, lightning, oil, oilfilter, part, water, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
