Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 01-29-2012, 09:19 PM
COLD1345's Avatar
COLD1345 COLD1345 is offline
Garage is empty, add now
COLD1345 is starting off with a positive reputation.
97 4.0 SOHC FPR ???
97 Explorer Sport 4.0 SOHC auto 4x4.
Here's my problem. The fuel pressure regulator is bad,but the ones I can get are not what is on the motor. The original fpr has the fuel line MADE on it and all of the replacement fpr's have a threaded port for the fuel line to attach to it. I have heard that Ford did this for a short period of time and then went to the other design. Can not find the original type anywhere.
My question.
Can I just change everything over to the other design? Even if I have to change the fuel rail that will be fine.
Anybody ever deal with this??
  #2 (permalink)
Old 01-30-2012, 01:18 PM
COLD1345's Avatar
Really??? No one???
  #3 (permalink)
Old 01-30-2012, 01:37 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has much to be proud of85e150six4mtod has much to be proud of85e150six4mtod has much to be proud of85e150six4mtod has much to be proud of85e150six4mtod has much to be proud of85e150six4mtod has much to be proud of85e150six4mtod has much to be proud of85e150six4mtod has much to be proud of85e150six4mtod has much to be proud of
Well, haven't seen this question before. Don't give up yet--your post is at the top again and may get some more looks.
  #4 (permalink)
Old 01-31-2012, 08:06 PM
critterf1's Avatar
critterf1 critterf1 is online now
critterf1 is gaining momentum as a positive member of FTE.critterf1 is gaining momentum as a positive member of FTE.
Change it over and never look back.
__________________
Speed is a question of money. How fast "CAN" you go?
  #5 (permalink)
Old 01-31-2012, 08:14 PM
COLD1345's Avatar
Quote:
Thanks!
Do you have any idea what years will interchange? I have looked at about 5 different Explorers and none of them have what I need to change it over. This is a 97 4.0 sohc and the ones I have looked at have been 97-99 4.0 sohc and they are totally different. Didn't even see an fpr at all. Did Ford put 2 different fuel systems on these things??
  #6 (permalink)
Old 02-21-2012, 08:53 PM
crmarshall crmarshall is offline
crmarshall is starting off with a positive reputation.
Yes Ford did put two different fuel systems in. Your 97 is a return style and the 99 is a non return. Your system bleeds pressure off at the fuel rail through a line back to the tank. The 99+ just bleeds it of at the pump in the tank. I don't know the answer to your question. I am having issues with my 98. I may end up getting a regulator from the parts store and having a hose made up at Evco or another hose house locally.
__________________
2005 F250 Crewcab XLT Lariat FX4 6.0 PSD
Bone stock
124,000 miles
285/70/18 BFG AT's
Spray in bedliner
Tags
1997, 2002, 40, custom, exhaust, explorer, ford, fuel, montana, pressure, rail, regulator, sohc, sport, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
