well its not a tank float in my case, just yanked it out and set it in a bowl of gas, spun it every which way and didnt see a bubble or get any in the float.
Im going to breakdown and pick this up from autozone for $20. Equus/2 in. 73 Ohm empty / 10 Ohm full Back-Lit 90 degree sweep fuel level gauge for Ford and Chrysler
You can go to Radio Shack and pick up a 10-ohm resistor for a buck or two. Lift the wire to the tank, hook up the wire to the resistor and ground the other side of the resistor. Does the gauge read full? If not, some simple arithmetic will tell you what the full-tank resistance should be.
If you get a reading of half-tank with the 10-ohm resistor, the float you are proposing has too much resistance. You need a float that has 5 ohms resistance at full.
Make the test and come on back in with what you find.
David, do you have or can you borrow an ohmmeter? Do this:
Lift the wire to your present sender with the tank full. Measure resistance to ground. To make the gauge read full scale with a full tank you need a sender with 3/4 of the resistance that you measure.
cougarjohn i appreciate the help. I guess im going to have to buy a new one. I went out there to check it but my digital numbers are going out. chinese junk
