140v Idm mod underway
Got started on the 140v IDM mod today. Removed it from truck, removed the cover using a heat gun (with no damage ) got my new resistors from digikey and hopefully tonight get the soddering done. took a few pics and will post later after the mission is complete. Any helpful hints are greatly appreciated.
Hi! Here's a good Thread - https://www.ford-trucks.com/forums/7...it-work-9.html - Post#122 had some good info for sealing the Board.
https://www.ford-trucks.com/forums/8...-140-volt.html
Splatts, if you haven't seen the above link you should review it.
If you are using the small resistor I think hot glue would be fine to secure it. Because you have used a hot gun to remove the cover I think you may have already seen the link. If you have any questions just ask, and good luck.
I got grey rtv to seal the lid, but I kept reading about sealing the sodder on the new resistor. I figures the dielectric silicone would do fine for that, and a dab of hot glue to hold the new resistor in place while I heat up the sodder a bit for the connection. I read of a few guys that just heated up the old sodder and didn't add any, cause too much is bad I guess.
You should really try to remove the old solder, they make some stuff that's called solder wick to clean the old solder off the pads, Radio Shack would have it I think. It is necessary to add a little solder if you don't get the old off for a good solder joint, and its not necessary to use a lot of solder, its preferable to be able to see a little lead definition . You don't need to cover the solder with sealant.
2400 rpm's at 75 mph. Good for towing , good economy, really good performance. I'm I can't imagine how you keep 31s hooked to the pavement, its tough enough with 35s
My dually is feeling gutless. Can't pull hills for crap with 1500lbs on the back plus the weight of the steel flatbed. I have searched for leaking up pipes but havent found any signs of leakage. I will definately have to wait until tomorrow night so I can swing by RadioShack and pick up a few things it sounds like I need.
