Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #31 (permalink)
Old 01-31-2012, 08:05 AM
fordpride's Avatar
fordpride fordpride is offline
1997 Ford F-250
fordpride has a great reputation on FTE.fordpride has a great reputation on FTE.fordpride has a great reputation on FTE.fordpride has a great reputation on FTE.
Increases the voltage to the injectors to 140v fir better throttle response and a little better idle
__________________
Mike-97 PSD,auto,4.10LS,212,000 on the clock,Intercooler,StageII 180/80,Adrenaline HPOP,BTS tunes,6637,203* t-stat,Sunpro gauges,Areoforce Scangauge,lost kitty,muffler ran away, ,MBRP 3in. DP 5in. exhaust to 5in flat top black stacks,shift kit,smoked headlights,cab and tail lights all blacked out,hayden trans cooler. E-fuel laying on the floor.Louisiana FTE Member Map
  #32 (permalink)
Old 01-31-2012, 11:30 AM
jiveturkey692000's Avatar
jiveturkey692000 jiveturkey692000 is offline
Garage is empty, add now
jiveturkey692000 is starting off with a positive reputation.
I see, thanks.
__________________
Dan
94.5 F350 7.3 Turbo Powerstroke, 5spd. Crewcab. Dually. Valair Clutch and Solid Flywheel. 4.10's, 316,000 miles
82 Dodge W350, 360, 4spd, 4X4, Extended Cab.
95 Jeep Grand Cherokee 318, AT, 4X4, 2" lift, 30" tires
96 Fleetwood Mallard TT, 30ft/ 79 Trans Am 400, 4spd.
  #33 (permalink)
Old 02-01-2012, 08:41 AM
Splatts's Avatar
Splatts Splatts is offline
Splatts is starting off with a positive reputation.
Got the old resistor out this morning and making a stop at the shack after work to pick up a few important items. And recommendations for solder and what not?
  #34 (permalink)
Old 02-01-2012, 01:09 PM
79f-250custom's Avatar
79f-250custom 79f-250custom is offline
79f-250custom is starting off with a positive reputation.
Don't recall the actual size...Radio Shack carry's a very thin solder that contains silver.
Use that, flows quickly and at low temp.
this is the site i used when i did my mod.
http://www.ford-trucks.com/forums/84...ml#post7805706
go to page 4 that where i asked what solder to use.
hope this helps
mitch
__________________
________________________________
1995 Ford F-350 PSD quad cab dually.
1997 Ford F-350 PSD single cab 4X4,
FPR shim, 6637 intake, 140V IDM,
3" DP 4" exhuast, gauges, 20k mod,
ccv mod, EBPV gone!
  #35 (permalink)
Old 02-01-2012, 05:34 PM
Splatts's Avatar
Sweet thank man.
  #36 (permalink)
Old 02-01-2012, 11:58 PM
Splatts's Avatar
After dangling from a rope under a helicopter flying from tower to tower for 12 hrs and some Denny's for dinner, the resistor is in!!! After I got the thing anchored to something it was rather easy. Only my second time soldering!!! Thanks YouTube. Lol. Goin to tape the lid on and start the rig up tomorrow!! Fingers crossed. Lol
  #37 (permalink)
Old 02-02-2012, 03:44 PM
Quote:
Sounds fun! lol. I get sweaty palms just thinkin bout it!
__________________
Dan
  #38 (permalink)
Old 02-03-2012, 07:16 AM
Splatts's Avatar
IT'S ALIVE!!! 140v IDM mission complete, well almost. put it in the rig and she fired right up this morning about 30 degrees outside. just got to seal up the lid this weekend. thanks for the help fellas now i got to go be a dope on a rope my avatar pick is me hanging from the bottom of a helicopter doin about 80 mph working on the 500,000 volt powerlines. best rollor coaster ride ever. now i am off to do some more. 3 straight weeks!!!
__________________
97 f350 PSD, CC, 4X4, MT, Cali, 315-75/R16's, 116K, 140V IDM, dually, flatbed w/gooseneck, PTO driven winch, RiffRaff 6637/hpx, cat & muff del, DIY electric fuel, 3" DP, DIY dual 4" stacks, DP-Tuner F-6 chip, gauges(5)
  #39 (permalink)
Old 02-04-2012, 10:08 AM
Splatts's Avatar
Got the IDM all sealed up, goin to put it back in tomorrow or this evening. Also made a DIY boost leak tester. Goin to hook it up tomorrow and see if I can find me some leaks. I mounted a gauge on the PVC cap so as I am putting air to it I can watch the PSI at the same time.
__________________
  #40 (permalink)
Old 02-04-2012, 09:11 PM
Splatts's Avatar
Took the rig for a spin. Didn't notice a big difference other than a little smoother idle. I was able to get 17psi boost @ 3k rpms in 4th though. I heard the Cali split injectors have more spray than the non Cali single shot. Is that true?? Non Cali are around 95 cc and the Cali over 100cc??? Does that mean I can get more from the stock Cali injectors as compared to the non Cali injectors??? Just a thought.
__________________
  #41 (permalink)
Old 02-04-2012, 09:40 PM
fordpride's Avatar
1997 Ford F-250
AA injectors are 90cc non Cali
AB injectors are 120cc Cali
AD injectors are 140cc super duty
To run AB or AD in a non Cali truck you will have to have tuning for split shot injectors
__________________
  #42 (permalink)
Old 02-05-2012, 08:28 AM
Splatts's Avatar
I have a Cali truck, so will the AD injectors installed in my truck need a tuner?? That's about as much spray as a stage 1 single shot??? Should be able to get some pretty decent #'s out of that much spray with the addition of a tuner. I was thinking about goin with stage 1's or possibly stage 2's and a tuner, but I think by the looks of things I think a tuner or custom switch on the fly chip would make a huge difference. After I put my 35's on I am looking at goin with a chip or tuner.
  #43 (permalink)
Old 02-05-2012, 09:05 PM
Iallwork's Avatar
Iallwork Iallwork is offline
Iallwork is gaining momentum as a positive member of FTE.
You motivated me to do mine. Just waiting for the sealant to dry. Install tomorrow.
__________________
Steve
97 F-350 4x4 PSD, banks stinger kit, dp, EBPV gut, small housing, chip, FPR shim, 140v mod, 250,000 only owner.
  #44 (permalink)
Old 02-05-2012, 10:03 PM
Splatts's Avatar
Pretty easy when u got good tips from some seasoned veterans. After I get my 315 75r16 put on this bad boy then i am goin for a f6 chip from DPtuner. been scoping out some stacks and intercooler options too.
  #45 (permalink)
Old 02-05-2012, 10:18 PM
Iallwork's Avatar
Ya, I trust they guys on here more than myself. That's why it took so long to do the mod. Did it one handed (sorta)because I broke my Index finger on my left hand.
__________________
Steve
Tags
140v, 73, 73l, 97, cheap, diesel, ford, idm, mod, pictorial, resistor, sale, sealant, specification, tricks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
