slip yoke difference 4r100???
Hi Guys, Hope someone can help me out. I need a conversion u joint for a transmission swap. I have a l99 F250 2wd with 4r100 and blown pump and clutches. I have a take out '03(trans tag says 03) 4r100 from a 7.3 E350. Both slip yokes are 31 spline and the tailshaft opening is the same. The u joint is different as is the slip yoke outside dimension (Diameter). Does anyone know of a 331 to 330 u joint? My other options are to swap tail sections or turn the f250 yoke down to the new diameter. Am I missing anything. Trans bolts up and sensors swap. Only the speedo is somewhat different.
Thanks in advance.
Shane
Thanks in advance.
Shane
88gtblack
06-05-2013 06:18 PM
