Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 01-29-2012, 10:25 AM
Bogus Exception's Avatar
Bogus Exception Bogus Exception is offline
2001 Ford Excursion
Bogus Exception is starting off with a positive reputation.
Smile Funny hatch strut story...
My 2001 Limited 4x had rear hatch struts that went kaput. You had to manually heft the hatch up and hold it there.
I had shoulder issues (still do, in PT) completely unrelated to this, but I used it as an excuse to fix the struts to my wife. I read around here, and found out that my hatch would open more than it had when the struts were new. OK. So I ordered:
Code:
Lou Fishman
Lift Supports Depot.Com
A Division of Mr. Lou's Stuff LLC
P.O. Box 130998
Carlsbad Ca. 92013-0998
fax | 1.760.431.9814
e | Lou@liftsupportsdepot.com
w | liftsupportsdepot.com
Name                      Code                         Qty   Each  Options
Lift Supports 6421/48154  48154                          2  22.05
(Shipped)
                                                 Subtotal  44.10
                                Coupon discount (nye2012)  -5.29
                                                 Subtotal  38.81
                                                 Shipping   9.88
                                                      Tax   0.00
                                                    Total  48.69
...after reading recommendations about the 2x2 being 2" higher, etc. So I wait, and they arrive. Small triangular box, each wrapped in plastic individually. So off I go to a friend's to "slap these babies in", I think I said.
We rig a piece of 2x4 to hold the door open and remote the driver's side. Comes off really easily. But as we go to do the passenger side, I said something stupid like "Don't you think we should keep it on, just in case there is an issue?".
So we take out a new one, block the door wide open with a 2x4, and guess what-the new ones don't fit! They are too long! OK. So I say something equally stupid, like "All we need to do is compress these a little, and they will snap right on". Well, the result of literally 2 hours of ingenuity and web searching is that you cannot compress these babies. So we're screwed. We cannot compress the new strut enough to get it into the snaps/attachment points on the truck.
So I FINALLY say something smart: "Do you think having the old strut on there is keeping the door from opening further?". The struts were installed in less than 60 seconds after the remaining old, short strut was removed.
So there is a moral to the story somewhere in there, but the good news is that the door opens so much now that I have to reach WAY up to grab the handle in order to bring it down-and I'm a solid 6'01" tall!
Thanks to everyone for the recommendation to/for Lou's, and the exact part you all specified (above) worked fantastic (as soon as I removed the old ones...)
pat
  #2 (permalink)
Old 01-29-2012, 10:30 AM
njneer1's Avatar
njneer1 njneer1 is offline
2000 Ford Excursion
My Garage
njneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to all
At least you spent some time with your friend .....good time to catch up and kill a few beers !
__________________
2000 Excursion, 7.3L, 315 General AT2, super chips 1705,EGT/boost/ trans temp. 4" lift, F250 Rough Country, Redhead, 2.5" front leveling springs, 2" rear F250 add a leaf
1988 Bronco 4.9L, I6, 5spd, 33" BFG A/T's Redhead..for the fire trails, Yes the 33's rub on tight turns.
1985 Bronco 4.9L I6 4spd....will be ready for the trails this spring
  #3 (permalink)
Old 01-29-2012, 03:06 PM
wpnaes's Avatar
wpnaes wpnaes is offline
FTE SoCal Chapter LDR
2000 Ford Excursion
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Indeed, the best part.
__________________
Sean
2000 Excursion XLT V10 4x4 170K, front V's, rear mod'd C's,, 315's, winch bumpers F/R, Viair system, Piaa lighting, Hellwig rear, dual Optimas, oily K&N, RedHeaded, scratchy paint, love taps at each corner.
Join the So Cal chapter here
  #4 (permalink)
Old 01-29-2012, 03:16 PM
2001 Ford Excursion
It was too late to start drinking that night, as someone (who shall remain nameless) had us beating our heads against the wall trying to figure out the hardest way to do a 2 minute job...
pat
  #5 (permalink)
Old 01-29-2012, 03:21 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
2005 Ford Excursion
Misky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud of
Pat,
Welcome to FTE - and thanks for posting your story.
Funny how sometimes we over think things.
__________________
2005 EB Excursion 2wd 6L PSD 3.73/LS Mich LTX M/S2, Diesel Kleen (gray bottle), RAS, Read Head Steering, scangaugeII w/Blendmount, SPAtechnique gauge (Fuel Pressure & Volts), blue spring, Air Lift 1000 air springs, Interior Dome Override, DieselSite Coolant Filter, BPD Oil & EGR coolers, Rancho RS9000, Hellwig, Diehard Platinum x2 (mine)
2004 EB Explorer 4x4 stock (hers)
2000 Jeep Sahara 4x4 2" lift, Warn winch, detroit lockers front and rear (ours)
  #6 (permalink)
Old 01-29-2012, 04:14 PM
tims01's Avatar
tims01 tims01 is offline
Garage is empty, add now
tims01 has a good reputation on FTE.tims01 has a good reputation on FTE.tims01 has a good reputation on FTE.
bwaaahahahahahhahahahahahahahahahahahahahahahahaha hahahahahahah i did that to but i only spent 5 min trying to compress them lol
  #7 (permalink)
Old 01-29-2012, 04:37 PM
2001 Ford Excursion
Quote:
Originally Posted by tims01 View Post
...i did that to but i only spent 5 min trying to compress them lol
We had all manner of belts, tie wraps, tape, bolts, clamps, both of us holding it, you name it-we tried it. All the time searching the Internet, wondering why everyone else seemed to have no problems!
Oh, and thanks for not making me feel any more embarrassed! :)
pat
  #8 (permalink)
Old 01-29-2012, 04:53 PM
jasonodsky's Avatar
jasonodsky jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
Welcome Pat and thanks for sharing. I think we all have a moment like that somewhere in life. Sounds like you weren't really buying struts but a few uninterrupted hours with a friend.
__________________
2004 Excursion XLT, 4X4, V10, 3.73 - pulling a 30' Hornet Travel Trailer 154,000 mi - 09/2010 - new to me 163,500 mi - 02/2012 174,000 mi - 4/2013
  #9 (permalink)
Old 01-29-2012, 06:35 PM
tims01's Avatar
Quote:
^^^BINGO^^^^
pat
WELCOME
  #10 (permalink)
Old 01-30-2012, 08:11 PM
stupidloud's Avatar
stupidloud stupidloud is offline
stupidloud is starting off with a positive reputation.
I ordered the same struts from the same place, the part number on the bag matches, but my hatch wont close. The struts are too long! And not by a little, by a lot. Can you measure the body of the strut, and let me know how long yours are? I would really appreciate it. From the very top to the end of the barrel would be great.
__________________
2001 Excursion Limited, 4x4 V10, Dynomax Xtreme muffler, 33x12.5 DC FCII's on 17x10 rims, Blacked out badges and grill. Custom audio 2x Audison LRx5.1k amps, 2x Hertz Mille MLK 2, 2 18W3s
Dual Marine DC 180 batteries with an isolator, 1500 watt Tripplite UPS inverter
2006 Impala SS (wifes car)
  #11 (permalink)
Old 01-30-2012, 08:58 PM
2001 Ford Excursion
Quote:
@StupidLoud,
Sure thing. One question, though, do you have a 4x4 or 4x2? Believe it or not the doors aren't the same (for some stupid reason). Off the top of my head I think the ones that came out were 14's, and the new ones were 16's-but don't take any stock in that. If Lou won't tell you, I'll get out there soon and measure.
pat
  #12 (permalink)
Old 01-31-2012, 11:51 AM
dockrocker's Avatar
dockrocker dockrocker is offline
dockrocker is starting off with a positive reputation.
Did the same thing until the light bulb went off!
__________________
"Good. Bad. I'm the guy with the gun." - Ash Williams, Housewares.
  #13 (permalink)
Old 01-31-2012, 09:03 PM
fordboy67's Avatar
fordboy67 fordboy67 is offline
fordboy67 is a splendid one to beholdfordboy67 is a splendid one to beholdfordboy67 is a splendid one to beholdfordboy67 is a splendid one to beholdfordboy67 is a splendid one to beholdfordboy67 is a splendid one to beholdfordboy67 is a splendid one to behold
A bad day/night working on your rig is better than a good day at work! Especially with buddies!
__________________
Chuck
2002 Excursion Limited 4X4,V-10, K&N, Warn hubs, Optima Yellow Top,285 Goodyear Wrangler Silent Armours, SCT Tuner from 5 Star, Gibson cat-back exhaust, Raybestos R300 rotors & pads, RAS.
  #14 (permalink)
Old 02-01-2012, 12:14 PM
2001 Ford Excursion
@fordboy67: Amen, Brother!
Speaking of Brothers, any Traveling Men with Ex's on this form?
  #15 (permalink)
Old 02-01-2012, 12:58 PM
Bigdaddybus's Avatar
Bigdaddybus Bigdaddybus is offline
2005 Ford Excursion
Bigdaddybus has a good reputation on FTE.Bigdaddybus has a good reputation on FTE.Bigdaddybus has a good reputation on FTE.
Awesome story!
I would have rather gone your route than the way I did....let me just say I had a bump on the top of my head for a good 10 days from the hatch, and I am lucky I didn't knock myself out cold.
The new struts are great, aren't they!
Tags
auto, code, coupon, depot, edge, excursion, ford, hatch, lift, lou, mod, nye2012, parts, strut, struts, supports
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
