Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-29-2012, 04:38 AM
René1234's Avatar
René1234 René1234 is offline
Garage is empty, add now
René1234 is starting off with a positive reputation.
Where to find power wire for backup camera and monitor ?
Hello Ford Expedition Enthusiasts,
Last month I have installed a backup camera (inside on the liftgate door) and a monitor (left at the drivers dash) in my 2007 FE-EL Eddie Bauer. I used the power wire to the fog back light - the fog back light is mandatory here in the Netherlands, and I had them installed when importing the car from Florida. The power to the fog back lights runs only when first the front fog lights are turned un (the standard light switch pulled out).
I'm not so happy with this, since I now can only view my cam when putting fog front lights on.
Question: Is there a powered wire (always on when driving, e.g. for back lights) where I can tap on the power cable for monitor and camera ? Hopefully located in the left front, down near the pedal moving switch or in the wirng running underneath the step boards ?
Thanks !
Regards from the Netherlands, René.
P.S. If somebody is interested on the wiring and instalation of the camera and monitor, please let me know and I will upload the pictures I have made.
  #2 (permalink)
Old 01-29-2012, 05:20 AM
Ironhand03's Avatar
Ironhand03 Ironhand03 is offline
2003 Ford Mustang Cobra
My Garage
Ironhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputation
Ironhand03
You need to find a 12V power source that is hot only when you need it.
Your best bet would be to try to tie it into the reverse selector somehow. That way it only comes on when the car goes into reverse.
You probably could pull power from the reverse lights since these only come on when in reverse as long as the amperage pulled from the system isnt higher then it can take.
__________________
Cory
FTE Wisconsin Chapter Leader
*Click Here To Join*
98 Expedition. 4x4, DD
03 DSG SVT Cobra(Aiming For 1,000rwhp, Blower Only)
2012 Ford Fusion. SEL AWD, Fully Loaded.
  #3 (permalink)
Old 01-29-2012, 05:56 AM
René1234's Avatar
Alternative ?
Hello,
I would prefer to be able to use the cam anytime, e.g. fir monitoring the load during hauling. Is here any wire nearby the lowr left dash area that is hot when driving ? If yes, what color(-s) dies it have ?
Thanks !
René
  #4 (permalink)
Old 01-29-2012, 07:01 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
If you have the HD trailer tow package there's the "12v Aux (trailer battery charge)" connection that's hot all the time the ignition is ON.
-- Chuck
  #5 (permalink)
Old 01-29-2012, 08:02 AM
René1234's Avatar
Hello Check - do you have a clue about the color code of this wire to identify it ? Is it running along the left side of the car underneath the door step panels ?
Thanks !
  #6 (permalink)
Old 01-31-2012, 05:58 AM
At the round RV connector (HD Tow) the standard wire color is black. Shows as OG in the diagram below. Pretty sure there's a connector at the back of the truck where the wire may change color as I've been told the "Bargman" RV connector can be added. If a separate harness runs back there there should be a Blue wire in it for the electric brakes. (Click on the little photos to get to the links.)
Click the image to open in full size.
There's a required relay and fuse in the trailer tow power panel on top of the radiator shroud that has to be installed. Came loose in a bag with new vehicle..
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Not sure the wiring is there if you don't have HD tow.
-- Chuck
  #7 (permalink)
Old 02-04-2012, 09:47 PM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
I did installed a back up camera in our '07 Navigator L.
Underneath the passenger's seat you'll find a green wire with a brown stripe. Actually, two of them!
One of them is the lead for the back up lights, and should you decide to use your camera strictly as a back-up cam, that wire is hot once you select reverse.
If you search the subject, or even posts by me, you'll find more details.
Good luck. For your intentions, the trailering harness sounds great.
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
  #8 (permalink)
Old 03-03-2012, 01:54 PM
TCAS007's Avatar
TCAS007 TCAS007 is offline
2007 Ford Expedition
TCAS007 is starting off with a positive reputation.
René,
where did you install the fog lights at the tail?
Are red turn signals allowed in NL? They're not in many EU countries and most convert the backup lights as turn signal
Did you solve the problem? Show us a pic of the back of your Expedition please.
  #9 (permalink)
Old 11-22-2012, 01:03 PM
Cris007 Cris007 is offline
Cris007 is starting off with a positive reputation.
2007 Naviagtor back-up camera power
Hi friends,
Thanks for posting all this info.
I have a 2007 Navigator and was wondering if I'd be able to find power wires for the back-up lights in the lift-gate.
I'm looking to install a wireless back-up camera (above the license plate) and all I would need is the back-up / reverse 12v to power it up when backing-up.
Your help is much appreciated!
  #10 (permalink)
Old 11-25-2012, 02:42 PM
outdoorguy outdoorguy is offline
outdoorguy is starting off with a positive reputation.
backup wires in liftgate?
I'm looking too. Just picked up the Magellan gps with backup camera. "Hoping " the back up light wire is already there in standard harness since it is a factory option.
Quote:
Originally Posted by Cris007 View Post
Hi friends,
  #11 (permalink)
Old 03-12-2013, 07:36 PM
mwells mwells is offline
mwells is starting off with a positive reputation.
I just completed this identical installation. I had a wiring diagram for the factory bu camera and tried to locate the power supply for that without success.
I ran a separate wire from the backup lamp, neatly along the gasket, and then alongside the flexible boot which goes into the lift gate (attach it with a lightly tightened cable tie. This will get power to the transmitter.
I connected a second ground wire to one of the bolts holding the wiper motor, and routed down into the gate. I secured the transmitter to a brace with 3m double sided mounting tape and a cable tie. Gather all neatly with cable ties and secure them.
I led the camera wire through the license plate light, by removing the assembly from the outside, routing the cable ( leave enough slack for removal ), and reinstalling the assembly.
Test the installation before you button it up. My works great. Hope this helps.
Tags
2003, auto, back, backup, camara, camera, f150, ford, front, fuse, light, power, reverse, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
