Cutting the bed, short bed conversion. - Ford Truck Enthusiasts Forums
Old 01-28-2012, 11:30 PM
1800joedaddy's Avatar
1800joedaddy 1800joedaddy is offline
1800joedaddy is starting off with a positive reputation.
Just inherited a 76' trailer special ex cab long bed from my daughter. I hate long beds on anything but a reg cab so the bed is doomed. The side are excellent but there's holes in the floor so I don't have a prob cutting it. I just would like some input from guys who've done it. I've heard of guys doing this but it seems pretty tough. Any tips?
Old 01-28-2012, 11:59 PM
kevin316's Avatar
kevin316 kevin316 is offline
kevin316 is starting off with a positive reputation.
There is a current thread on here where someone did this. I think it is a crew ab shortbox he is building.
I found the post
http://www.ford-trucks.com/forums/11...cab-build.html
Old 01-29-2012, 12:05 AM
JB78f150's Avatar
JB78f150 JB78f150 is offline
JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.
Redsuperduty did it this way.
But I've seen people cut about six inches before the front of the bed then take out what you need farther back then weld back on the front six inches. Does it have the front tank door? It is a 76 so I wouldn't think so.
Redsuperduty did it the best to me a lot less body work.
Old 01-29-2012, 12:07 AM
JB78f150's Avatar
Just take a drive to Indiana and Redsuperduty will make it shorter for you
Old 01-29-2012, 01:18 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
I have to add that shortening the frame like RED did is the absolute worst way to do it. You always "Z" the frame and add fishplate backers on each side.
One good dip in the road and the truck is going to buckle like a trampoline.
Josh
Old 01-29-2012, 01:23 AM
JB78f150's Avatar
Ya, I was going to say that. Saw a thread a while back where someone did that. I was just referring to Red's thread cause I like the way he did the bed side.
Also I think he boxed the frame so that added some strength.
Old 01-29-2012, 01:35 AM
Bullitt390's Avatar
I just realized I failed to mention he (RED) did a fantastic job shortening the bed. But the frame...
I snagged those pics off of Fordification... I couldn't find the pics where he backed the welds.
Another example...
Josh
Old 01-29-2012, 04:52 AM
USArmyTaterness's Avatar
USArmyTaterness USArmyTaterness is offline
USArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant future
That looks like the way to go hmm keep my long bed or go short bed. I hate you all you never let me get set on an idea.
Old 01-29-2012, 08:32 AM
Thanks! It's actually a single rear tank, odd because it's a "Trailer Special". I would think dual tanks would've been standard equip. Definatelt doing a Z notch. While a butt weld in a diagonal is better than a vertical butt I want more radial strength. I've done a few frame stretches and notches so I think I can get through that part good enough. The Bed is my main concern. I'll get some pics up.
Old 01-29-2012, 08:54 AM
redsuperduty's Avatar
redsuperduty redsuperduty is offline
redsuperduty is gaining momentum as a positive member of FTE.
Josh
I am a certified welder, a proper butt weld is stronger that the steel used in our 70's truck frames. I didnt need to, but did plate it on the back with the cut out pieces. I took an inch of hieght out of them so they fit pefrectly in the C channel frame. In effect, it is double framed at the splice. There is no right way or wrong way to do this, as long as a good welder does the welding and the correct measurements are done. I agree, the angle cut looks cool but substandard welds will still let it break apart. There isnt a dip in any road that will break my splice.
Thanks for the compliments on the bed, I'll round up some more pics.
Old 01-29-2012, 09:08 AM
Photo Bucket SUCKS!!!!!!!!!!!!
Old 01-29-2012, 09:18 AM
'79Fordpilot's Avatar
'79Fordpilot '79Fordpilot is offline
'79Fordpilot is starting off with a positive reputation.
Also consider that when shortening the bed by removing material from the front, you will be losing the front stake pockets. That was done on my truck which I am OK with. I put the cut-down long bed on a SWB truck frame.
Old 01-29-2012, 09:34 AM
79fordpilot is exactly right. It wouldn't be a big deal to graft the inside ''bulge'' and the pocket holes in there, I just welded the rest of them up for a clean look. Around min. 3:50 in this video of my other truck you will see step by step of shortening a long bedside, including moving a stake pocket hole.
1978 Ford F150 Ranger Lariat 4x4 - YouTube
Old 01-29-2012, 09:38 AM
Photo bucket has gone mad so I can't resize these.
Old 01-29-2012, 11:43 AM
Stop putting music in stuff I can't watch it hmmpf.
Long bed box score on Craigslist F250Rob 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-27-2016 06:50 PM
Short, Long or Medium Bed Texasknowhow 1967 - 1972 F-100 & Larger F-Series Trucks 37 01-19-2015 10:29 AM
pictures of single cab long bed vs 6.5' bed? choate 1987 - 1996 F150 & Larger F-Series Trucks 39 05-26-2014 10:14 PM
Front bed panel replacement. pinkpanther 1973 - 1979 F-100 & Larger F-Series Trucks 0 10-23-2013 05:40 AM
53/56 Long Bed or Short Bed DasHaas 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 04-26-2012 10:08 PM
Tags
1978, 460, 73, bed, bedshort, classic, conversion, duty, f100, f150, f250, ford, long, rcsb, short, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
