How to disable daytime running lights.... - Ford Truck Enthusiasts Forums
Old 01-28-2012, 07:48 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
I just installed the relays and 12g wire for my headlights and it works great.
BUT....
When I just have the truck running and headlights off the daytime running lights is screwing up the relays. That just sit there and buzz. Like not enough power to properly close the circuit.
How would I disable the daytime runnin lights? Or any other suggestions? Once the headlights are on the buzzing stops and they work great. It's just the damn daytime running lights that are messing with me now
Old 01-28-2012, 07:53 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Just drive with the headlights on, its safer.
Not sure on these trucks, didn't even know it was an option. On newer vehicles its a different headlight switch.
Old 01-28-2012, 07:57 PM
Canadian vehicles it's mandatory and has been for many years. There's no switch for it. When the key is on if the headlights aren't the daytime running lights are on.
I don't want to have to use my headlights during the day. And don't want to burn out that relay either
Old 01-28-2012, 08:00 PM
Edgethis's Avatar
So if its mandatory in Canada, and you still live in Canada....why do you want to disable them? Wouldn't that net you a ticket?
Old 01-28-2012, 08:04 PM
They won't ticket for it. But it won't pass inspection with out them. I'd like to just unplu the module or something if I can. Unles there's a way to make them work and not make the relay buzz
Old 01-28-2012, 08:11 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Remove the DRL relay.
Old 01-28-2012, 08:26 PM
It doesn't show a relay in the owners manual. It shows a 30A fuse which is for daytime running lights, headlight flash-to-pass and horn.
And a 15A fuse for daytime running lamp module, back up lights oxygen sensor heater and trailer battery charge relay.
Anyone know where the module is? Maybe I can just in plug it
Old 01-28-2012, 08:32 PM
Nickk97tml's Avatar
Nickk97tml Nickk97tml is offline
Nickk97tml has a good reputation on FTE.Nickk97tml has a good reputation on FTE.
Its a module on the drivers side of the rad support. Its hard to get at. I disabled mine cause the truck looks hella mean with the side markers and signal lights on. Its only mandatory on newer vehicles obviously older vehicles on the road did not have them so no one is going to say anything. Just unplug all wires going to and from the module.
Its kinda peeping out in the picture, the module itself is placed at an angle on the rad support.
Old 01-29-2012, 07:32 PM
Got it, thanks!
DayTime Running Lights disabling surreyboy 6.7L Power Stroke Diesel 7 11-02-2015 12:07 PM
2001 SD Daytime Running Lights Hawk180 1999 to 2016 Super Duty 13 05-16-2011 05:31 PM
Daytime running lights. herothc2003 1997 - 2003 F150 8 01-07-2007 07:51 PM
daytime running light problem i3shooter Electrical Systems/Wiring 1 10-31-2005 05:26 PM
Daytime running lights??? owenlo 1999 - 2003 7.3L Power Stroke Diesel 5 11-18-2004 05:22 AM
Tags
2010, 2011, 2012, day, daytime, disable, drl, f150, f250, f350, ford, lights, mustang, running, time, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
