Which steps should I get?
It will be a little longer, I called a week or so ago and was told 3-4 more weeks. Hopefully I'll have them soon, I will make sure to post pictures.
Oh. That puts a different light on it. Can you give some more details / pictures to compare? The problem is that there are not many choices out there when it comes to W2W boards for an screw 6.5' bed. And that's what I really want.
flixden, my vote is for the Luvernes for the same reason as a few others have mentioned - they are more flat and thus you run less of a chance of slipping off them if you don't happen to be stepping on one of the pads.
I'm considering them for my truck. Need to shop around and see what the Canadian pricing is like. I like the build quality of the N-Fab 6-step bars but not the design (individual drop steps off the main bar vs. the clean, continuous look of the Luvernes).
If the rear end of the bars mounted to the box for support, I could see some major issues resulting from frame flex and the movement of the box and cab independent from each other. The bars would become a structural member, limiting this motion which is natural for pickup trucks over uneven road surface. I don't feel that the 14" or so hanging behind the rearmost bracket would cause any problems. Just don't do jumping contests off those ends....use good judgement.
The problem I see with most of the W2W bars is how they mount. Most of them float that bed portion out there with no mount or support past the rear door. I'd look at the mounting points of both. If only one had a mount back by the bed portion, I would go with that one. If they both do, I would get the stainless.
You're right about the rear bracket. Once I started researching more I realized all brackets would have to be on the cab, or to the frame. I like the brackets better on the Luvernes, but the Omega steps bars are only half there structurally. They are just a flat top surface with a rolled front edge to give the look of a tube. I haven't seen any in person but I'm not thrilled with that design. But they do have a more rearward 4th mount that attaches to the frame too.
I was comparing the pictures on the websites. The Luverne site lists the specific item numbers when you look up the steps (per truck model). Click on the item number and it opens the instruction page showing the parts. There are separate item numbers for both the step bars and the mounting brackets.
Thanks Ford8572 & McDavis!
cdnfireman, do you have pictures? That would be nice to see how they look!
Oh, now I see what you mean with the "half tube" when looking at the instructions.
Good point. Darn, I would have been very surprised if I would have ordered these. That's weird, I am wondering if the product is really as shown in the instructions. I would have expected the full oval tube. Thanks for pointing this out, so now the Luverne's are out I guess. Hmmm.
Here are the instructions with a drawing of the steps - in case somebody wonders:
http://www.luvernetruck.com/Product_...4_-551780-.pdf
What are FX2 steps? Do you have a link or picture by any chance?
#29
No pics. Next time you see a F150 FX2/FX4/Lariat with steps take a look at them. They should bolt right up to the XLT's. I haven't measured them or anything like that but they do look more functional that the ones offered on the XLT. I've tried the XLT' steps and will have to agree with most other folks that they are not very useful.
There is a guy at work with a F250 FX2 with steps that drop a lot more that any of the F150 steps. It's a regular cab 2WD diesel and his brackets probably drop the steps down 5 or 6 inches. I'm pretty sure it's factory steps. Looks just like the F150 steps with different brackets.
I wonder if Ford engineered these steps all the same but with different brackets for different frames?
