Fifth Wheel Prep Pack. and Pullrite slider - Ford Truck Enthusiasts Forums
Old 01-28-2012, 09:00 AM
kubatob7500 kubatob7500 is offline
kubatob7500 is starting off with a positive reputation.
Looking at 2012 F350 SB and it has 5 er prep package.
I curently have a 04 F250 SB with pullrite slider hitch.
I would like to know if anybody has heard of a converstion for this configuration.
I love pullrite hitch and would like to keep hitch. Love how it auto slides, no worries and want to put in new truck.
Old 01-28-2012, 09:33 AM
Budlight592's Avatar
Budlight592 Budlight592 is offline
Budlight592 is starting off with a positive reputation.
I didn't know they did the prep in swb trucks. But here is the adapter I use in mine to allow me to use my old hitch.
http://m.youtube.com/#/watch?desktop...y9gWz7kk&gl=US
Old 01-28-2012, 10:31 AM
Looked at link to you tube and did not see video
Old 01-28-2012, 11:36 AM
Oops wrong link google Reese 30156 etrailer has the best website for viewing.
Old 01-28-2012, 11:47 AM
Also don't order crap from hitchanything.com they will give you the run around and not ship it out FYI. Took me over 2 weeks to figure out they were not going to ship it after they billed me and then another week for them to cancel the order and refund my money. While all that was going on my local truck guy had mine sitting in his place the next day and put in the truck a few bourse later bymyself.
Old 01-28-2012, 06:56 PM
Toyhauler Tug's Avatar
Toyhauler Tug Toyhauler Tug is offline
Toyhauler Tug is gaining momentum as a positive member of FTE.
They will put in the hitch prep but you cannot order the factory installed hitch with a short bed. Try U-Haul for towing supplies. I have been pleased over the years by the availability and prices. They install anything they sell, and it seems like wherever you are, there is one close by.
Old 01-29-2012, 09:12 AM
Double-Trouble's Avatar
Double-Trouble Double-Trouble is offline
Double-Trouble is starting off with a positive reputation.
You will need to remove the factory prep and get a new frame mount kit from Pullrite. The factory prep will unbolt from the frame. I don't know if the holes in the bed will be in the same place . I took mine out of my 05 and installed it in my new truck. Great hitch.
Old 01-29-2012, 03:02 PM
garrettwynne garrettwynne is offline
garrettwynne is starting off with a positive reputation.
Quote:
My 2011 Job 2 is a short box with the prep in from factory. Also, I pull a 36' 5th wheel with no problems.
Old 01-29-2012, 03:08 PM
ogreyghost ogreyghost is offline
ogreyghost is starting off with a positive reputation.
opinions wanted, I have a 2011 f350 and need a 5th wheel hitch, witch ones are the better ones out there. I live in phx az so everythings available
Old 01-29-2012, 03:16 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Thumbs up
Reese Elite or B&W setup...
Install of a B&W from an FTE member...
<iframe width="560" height="315" src="http://www.youtube.com/embed/FiOBK4tfINs" frameborder="0" allowfullscreen></iframe>
biz
Old 01-29-2012, 03:40 PM
Thanks for the video I can do this myself with a little from my friends Does the b&w double as a gooseneck also or did it just look that way?
Old 01-29-2012, 04:13 PM
biz4two's Avatar
Arrow
Surething. Yes...it does do both.
biz
Old 01-30-2012, 02:52 PM
RuhtraRon RuhtraRon is offline
RuhtraRon is starting off with a positive reputation.
Quote:
I spoke with someone at PullRite and they are coming out with an adapter for the Ford Prep Kit so you can put your SuperGlide in it. No need to uninstall the factory prep package. Sounds like it should be available within the month.
Old 01-30-2012, 04:26 PM
JohnD333 JohnD333 is offline
JohnD333 is starting off with a positive reputation.
Both Airsafe
Installation Rails
and Trailersaver
New! The BD3 Air-Ride 5th Wheel Hitch.
sell adapters. Confirm that their adapters include the Ford donut parts or if you need to buy them separaterly.
The donut parts are what is sold by Ford (and now others) to convert your old "Reese Elite" aftermarket underbed hitch to "Reese Elite" hitch that will fit the 2011 factory prep. You also rotate the Reese base 180 degrees to move the centerpin forward for the 2011 setup. If youfail to do so, the pin will be behind the rear axle causing a lot more sag...
Also, FYI, earlier aftermarket underbed adapter plates for the early (pre-2011) puck systems will not work on 2011 factory prep- the donut bolts are shorter, smaller diameter, and the hitch pin position in the bed will end up behind the wheel (like not rotating the elete hitch 180 degrees). I know Airsafe has this figured out because I helpd get them there. Trailsaver's photos look like they have also.
Old 01-30-2012, 05:42 PM
porthole's Avatar
porthole porthole is offline
porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.
An FYI for those using the Super Glide, the best pricing I found for the Slip Plate was the Slip Plate website.
I bought 6 cans (case) at a time and got the best price, free shipping and no tax.
Firestone riderite bags with pullright slider? rtazz17 6.7L Power Stroke Diesel 18 09-04-2013 11:51 PM
PullRite SuperGlide "ISR" series hitch ? my996duc1 6.7L Power Stroke Diesel 8 11-28-2012 11:01 PM
Pullrite 5th wheel adapter RUN52 1999 to 2016 Super Duty 2 09-18-2012 04:09 PM
Superglide 5th Wheel Questions the_justin Fifth Wheel & Gooseneck RV Towing 22 04-19-2011 05:59 PM
pullrite hitch luvcycles 2 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 18 02-19-2010 08:36 AM
Tags
30156, 5th, f250, ford, hitch, package, prep, puck, pull, pullrite, reese, rite, superglide, wheel, youtube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
