fuses
fuses
found the fuse panel under dash, what a nightmare 1 fuse has had new wire soldered to the outside!! & 2 fuses the glass is broken but wire intact but not sure if working properly.
What I need to know is what amp are the fuses meant to be?? fordifiacation wire diagram says 2 2A, a 30A, a 14A & a 15A the 2 with broken glass I took out were 15A, the problem I have is they are different lengths!!! I can't find anything online in UK or USA, anyone help me with part numbers, fuse lengths, where I might be able to get them, how do I tell what posistion they come out of as even with a flashlight I can't read the writing on the fuse panel, my truck is now dead till further notice wrapping fuse wire round the fuse holder is not an option!!
Thanks guys, really appreciate all the help I've been getting.
http://www.fordification.com/tech/im.../fusepanel.jpg
Seems to be some conflict, if you check the masters dtagram you can find fuse box with ratings.Hope this helps.
Ford Truck Technical Drawings and Schematics - Section H - Wiring Diagrams
Kasilof Ron
09-10-2004 10:01 AM
