94 F150 4WD Problems - Ford Truck Enthusiasts Forums
Old 01-27-2012, 08:43 PM
FordGirl1993 FordGirl1993 is offline
FordGirl1993 is starting off with a positive reputation.
Talking 94 F150 4WD Problems
Okay, so we have purchased a 4x4 shift on the fly button. And that was sadly not the problem. We have no clicks, no lights, basically no nothing involving the 4WD. We have locking hubs and have checked all fuses. Main question is how do we test the new control module light system (just purchased today) ? Also, if any new thoughts on what else our issue could be.
Old 01-27-2012, 08:56 PM
justforkicks's Avatar
justforkicks justforkicks is offline
justforkicks is gaining momentum as a positive member of FTE.
A DMM can be your best friend when it comes to electrical problems. Have you bench tested the actuator on the t-case? If you live anywhere there's salt, the actuators tend to go bad in these.
Old 01-27-2012, 08:59 PM
Sorry, not to familar with the terms exactly. DDM?? And also is there a chance that the actual wires could be bad. He just did the test and the light on the control module does not keep a constant flash for the advised flash per second. I am beginning to think that maybe the connectors could be the issue??
Old 01-27-2012, 09:03 PM
connectors could very well be an issue, along with the wires. a DMM is a digital multimeter. it'll test for voltage, resistance, and amperage in an electrical system. i'd go wire by wire and test for voltage. you don't want to see an ohm or more of resistance in any wire. ford connectors aren't that great to begin with (which i believe is their only downfall in this era).
Old 01-27-2012, 09:05 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
DMM= Digital Multimeter
Old 01-27-2012, 09:11 PM
Okay, we will try that. And we will probably try running 12v to the t-motor to see if that will possibly engage the motor. And do you possibly know where the GEM module is located or/and a picture would be fantastic.
Old 01-27-2012, 09:21 PM
if you can get the actuator off the t-case, then leave it plugged in and have someone hit the 4x and 2x switches. if the motor turns, then the problem is inside the t-case. if the motor doesn't turn, then check to see if the motor will turn by hand. if it can turn by hand, then the motor is not likely the issue. i *think* the GEM is up in the dash on the driver's side.
Old 01-27-2012, 09:40 PM
If the motor doesnt want to be hand turned should we try to hand turn it
Old 01-27-2012, 09:53 PM
76250_4x4's Avatar
76250_4x4 76250_4x4 is offline
76250_4x4 is starting off with a positive reputation.
i dont believe you will be able to hand turn the motor. if you are able too it will not move easily. the motor is able to turn the gear inside very easily, however the motor is not easily tuned by the gear. confusing huh? Anyways what im trying to say is just because you cant turn it dose not mean the motor is bad.
Now as far as having no 4x4 lights when you turn on the key is an indication that the control module is bad. i believe when you turn on the key the lights on the buttons themselves are supposed to flash very briefly, like not even enough to fully illuminate. if yours do not do this than your problem most likely lies in that area
Old 01-27-2012, 10:03 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Problem come on sudden or never worked as long as you owned the truck? Just buy the truck?
If never worked or been a while sense attempting to use 4w might be stuck from lack of use, not uncommon in that system.
Did you try simply smacking the shift motor with a hammer couple times (not hard just create some vibration) see if it shifts or attempts to?
Light is not going to light up until motor successfully shifts.
IIRC light only "flashes" if/when computer looses track of shift motors location, if it had not moved it the computer knows its location IE; 2H, it wouldn't flash.
Old 01-27-2012, 10:07 PM
76250_4x4's Avatar
are you sure danr1? every one ive ever driven the lights on the buttons themselves flash very briefly, not even enough to fully illuminate, just for a spit second right when the key is switched on
Old 01-27-2012, 10:30 PM
Quote:
No I don't recall that and while my experiences have been with little Broncos and Explorers (older and newer then the OP's truck here) they all use the same system/shift motor.
The light on the dash as I recall only lights up if the TC is in 4wheel. No light in 2H and light "flashes" when computer doesn't know where the shift motor position is.
Might "flash" if gear change is attempted say 2 to 4H for example and motor doesn't move at all IE; fails to shift, but don't recall that as fact.
Old 01-27-2012, 10:33 PM
76250_4x4's Avatar
i just checked my dads ranger and it does indeed blink the lights just for a split second when the key is switched on. it is very easy to see in the dark. turn the key on and off and watch it.
4wd not engaging 97 expedition ctown2 Expedition & Navigator 26 01-14-2017 08:41 PM
Ford f350 201 ambulance Toulousse General Automotive Discussion 3 09-11-2016 07:43 AM
New poster, crossroads, 6.2L blew up Brad Heil 6.2L V8 3 03-24-2015 10:00 AM
Manual 4wd Fordkindagirl97 Modular V8 (4.6L, 5.4L) 0 03-05-2015 07:44 PM
3 4x4 buttons in 07 Explorer khadma Explorer, Sport Trac, Mountaineer & Aviator 19 11-18-2011 08:23 AM
Tags
1993, 1997, 300, 4wd, 4x4, 94, 96, 97, f150, ford, il, indicator, problem, problems, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
