534 oil filter swap - Ford Truck Enthusiasts Forums
534 oil filter swap
Old 01-27-2012, 04:01 PM
deere81 deere81 is offline
deere81 is starting off with a positive reputation.
534 oil filter swap
I have a 534 and MT42 allison auto out of a fire truck with approximately 27,000 miles on it. It currently has the cartridge type oil filter and i'd like to install a later spin on filter. Does anyone know what the part number is for the spin on oil filter housing, and was it used on any of the other engines other than the super duty engines? Thanks!
Old 01-28-2017, 05:07 PM
Les milam Les milam is offline
Les milam is starting off with a positive reputation.
Quote:
if u use a Napa filter it part number is1515 what kind of oil do u use
Engine specs Jim534 401, 477, & 534 SD Engines 2 02-01-2017 09:21 AM
Ford 534 CI Jlmenz 401, 477, & 534 SD Engines 1 02-26-2016 09:08 PM
Converting oil bath air cleaner to filter style Mike-fire32 401, 477, & 534 SD Engines 3 06-06-2011 12:12 AM
Ford 534 pieces and demensions beegeezy 401, 477, & 534 SD Engines 29 10-05-2006 08:13 PM
I need info on my 534 Maximman 401, 477, & 534 SD Engines 5 02-16-2005 06:06 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
534, assembly, cartridge, conversion, convwesion, engine, escape, filter, ford, hybrid, kit, oil, replacement, spin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
