Axle upgrade to newer style (2012 Axle)
There was a thread on the 7.3L sub-forum about installing the newer E-Locker rear axle in older SD. The differential housing still has the boss for the VSS,...it just needs to be drilled/reamed and the hold down bolt drilled/tapped. Of course you have to install a tone ring on the ring gear too....and get the air gap correct for the VSS (Hall Effect) sensor to read correctly.
The following users liked this post:
I found that thread. I got all the information I need I believe. Thank you again for the info.
Posting the link..
https://www.ford-trucks.com/forums/1...f250-help.html
Posting the link..
edtahaney
09-11-2014 06:35 PM
