F150 5.4L strange rattling noise, PLEASE HELP, I need a idea!! - Ford Truck Enthusiasts Forums
Old 11-21-2014, 11:26 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
Print Wikipost
Old 01-26-2012, 07:08 PM
Sweetrocks Sweetrocks is offline
Sweetrocks is starting off with a positive reputation.
I got a F150 with a 5.4L and when I'm cruising down the highway every is goin well until I start to pull a hill. A loud fast rattle starts coming from the engine compartment, it sounds like it is mainly coming from the drivers side. The noise is really evident just before the truck down shifts out of OD, then its not as noisy and goes away when the truck is at full speed and not pulling a hill. The truck has lots of power and there are no check engine or fault lights on at all. The truck never hesitates. Interesting note, it doesn't make the rattle when revving the truck up in neutral. I really have no idea on this one and it is really starting to annoy the heck out of me when driving. Any ideas would be helpful me dearly. Thanks guys!
Old 01-26-2012, 07:18 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Sounds like detonation, have you tried a tank of hi-test?
Old 01-26-2012, 07:37 PM
Whats Hi-test? If it was detention wouldn't there be a check engine light??
Old 01-26-2012, 07:43 PM
Do you mean Premium Fuel?? If so, No I have not. I've been running 87 octane.
Old 01-29-2012, 06:33 PM
AppocAlexx's Avatar
AppocAlexx AppocAlexx is offline
AppocAlexx is starting off with a positive reputation.
you might look at the pcv valve i hurd a crazy sound coming from my engine and i started moving stuff and found that one of the pcv valves were either stuck or loose, either way it was bad i found an old one i had laying around, threw it in and havnt hurd it sense. the sound got louder as the engine reved up so hopefully this helps, the valves are located on both valve covers towards the back.
Old 01-29-2012, 08:26 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
X2 on pinging or aka pre detonation as stated try some higher octane fuel and you should be good to go..
Old 01-30-2012, 06:45 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I'd agree on ping too, mine has never thrown a code from it.
Old 01-31-2012, 10:52 PM
Feedguy Feedguy is offline
Feedguy is starting off with a positive reputation.
2004 F150 with similar issue
Mine did a similar thing, sounded like pinging, when moderate throttle pulling a hill for instance. Also had the idle knock. Got cam phasers changed noise gone. About 75000 miles.
Old 02-02-2012, 10:20 PM
nylroswell nylroswell is offline
nylroswell is starting off with a positive reputation.
Quote:
Sweetrocks is your truck 4X4?
Old 03-06-2012, 02:27 PM
Yea you bet my truck is a 4x4. I tried a higher octane fuel and It didn't clear up. Could using 5w-30 syn instead of 5W-20 be messing with the phasers ?? I run 5w-30 in all my company ford trucks and don't have these noise?? What do you guys think?
Old 03-06-2012, 06:51 PM
If it were only that easy
I suspect phasers. What is your miles on the engine??
Old 03-07-2012, 10:43 AM
72000Km, Truck got new phasers at 36000Km that were suppose to be the new generation phaser.
Old 03-07-2012, 09:57 PM
Timing chain
Was any work done on the timing chain?? I have read where the tensioners on some of these fall apart and the chain rattles. I am no mechanic. Just throwing out ideas.
Old 03-08-2012, 11:15 AM
I'd think it would be rattling all the time, not just at load if that were the case.
Old 03-14-2012, 08:11 AM
happycamper51 happycamper51 is offline
happycamper51 is starting off with a positive reputation.
2007 f150 4x4 5.4L rattling under hood
I experience similar rattling. Thought at 1st was piece of loose sheet metal vibrating. No grinding. Doesn't sound like detonation/ octane rattle, had tried higher octane gas, that didn't seem to make a difference. Crawled underneath last night cant see anything loose. Was looking for broken spotwelds on exhaust heat shields. Noise is definitely from cab forward. Noise appears at approx 40mph with slight throttle pressure where load increases up to point of downshifting transmission. Normal driving- no noise, no vibration. Cruising 55+- no noise. When it make the noise, you can depress brakes and it makes no difference. Vibration frequency not proportional to RPM. Any clues?
4.6L Engine Rattle when accelerating. morris_506 1997 - 2003 F150 9 01-15-2017 09:46 PM
engine rattling noise Fordperson Explorer, Sport Trac, Mountaineer & Aviator 1 03-28-2016 12:08 PM
Can anyone tell me what this sound is? MSG Milton 2009 - 2014 F150 5 03-16-2016 10:07 PM
Code Help: P0022 and P0345 Johnis 1999 to 2016 Super Duty 3 10-28-2012 12:30 AM
rattling sound 19expy97 2004 - 2008 F150 13 07-26-2011 11:32 PM
Tags
54, 54l, engine, f150, ford, intermittent, liter, noise, pvc, rattle, rattleing, rattling, sound, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
