NO VACUUM FROM ENGINE TO 4wd Solenoid
Old 01-26-2012, 05:12 PM
theduke308's Avatar
theduke308
theduke308 is offline
I have no vacuum coming from the engine to the IWE solenoid. This is making my hubs stay locked all the time. Can someone help me with where this line from comes from and how to fix this. Which line is the line from the engine, the one with the T in it or the other one?
5.4L V8 2004 New Style
Old 01-26-2012, 07:11 PM
CelticDevilDog's Avatar
CelticDevilDog
CelticDevilDog is offline
Check out this thread on the IWE system. It should be more than enough information to get you started with troubleshooting. https://www.ford-trucks.com/forums/8...then-some.html
Old 01-26-2012, 09:33 PM
theduke308's Avatar
theduke308
It was a bad check valve but the hubs still will not dis engage from the wheels
Old 01-26-2012, 09:40 PM
Rebuild101's Avatar
Rebuild101
Rebuild101 is offline
Reverse the vacuum lines on the vac silnoid to disengage the front dif
This worked on my 99 f150
Hope this helps
Old 01-26-2012, 09:56 PM
theduke308's Avatar
theduke308
I think on the "new and improved" f150s the vacuum is needed to unlock them
Old 01-26-2012, 10:30 PM
Rebuild101's Avatar
Rebuild101
Maybe is there 1 or 2 vac swiches for the front end?
One for engage and one for disengage
How cold is it I have seen the vacuum motor on the dif freeze due to moisture in the system
xjcamaro89
2004 - 2008 F150
447
01-31-2022 07:35 AM
Necronommicon
1999 to 2016 Super Duty
12-09-2016 01:05 PM
gpdickert
1983 - 2012 Ranger & B-Series
07-04-2013 09:01 PM
05pstroke
12-27-2007 01:51 AM
mprange
12-15-2003 11:17 AM
Quick Reply: NO VACUUM FROM ENGINE TO 4wd Solenoid
