Brakes for towing
Brakes for towing
Hi guys, I'm looking at replacing my brake rotors on my 2008 F150 5.4 V8. Should I go with cross drilled or slotted? I heard slotted only rotors would be better for towing. I did research and ran into this company Brake Rotors | Brake Rotors & Performance Rotors | Cquence.net.
I like there slotted only rotors:
2008 Ford F-150 RWD (Rotor Only) - Performance Series - Power Slotted Only Brake Disc Rotor [Front] | Cquence.net
They are about 190.00 for the front pair. Here is the drilled only rotors:
2008 Ford F-150 RWD (Rotor Only) - Street Series - Extreme Drilled Brake Disc Rotor [Front] | Cquence.net
I liked the drilled look better but what I'm really looking for is something with better bit to tow a small boat with.
Guys, thanks for the reply's. I'm aware of all those brands but they cost much more then the Cquence rotors. The Cquence rotors have good reviews and are comparable to the power slots/stop techs from what I've been reading. My main question is what is better for towing, cross drilled or slotted or dimpled? It seems they also offer dimpled rotors as well.
73z28cam
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
23
08-11-2020 12:16 PM
guthrie&co
13
03-06-2007 04:35 PM
