EXHAUST FLUID FAULT
#151
#152
#153
#154
My 2012 F-350 (built 05/17/2012) gave two Exhaust Fluid System Fault warnings this month. Both times the warning went away on its own within 10 minutes (first time after engine turned off, the second while parked and idling).
Both times there was no code in the computer showing a fault code. The first time the waring was Speed Limited to 50mph in 80 miles. The second time the warning was Speed Limited to 50 mph (yep, that part worked right away).
I took pics of the dash the second time and gave them to the dealer today showing both the fault and that DEF level was OK. I told him to find out what the fix is and let me know but there's no point leaving the truck with him today. Alternatively, I asked for the procedure to bypass the system (he laughed at that .
Everything I've read about this problem indicates there's no one solution and Ford is taking a shotgun approach to the solution sometimes replacing the NOx sensor, clear computer and reinstall software, replacing DEF sensor, or combinations.
A couple of questions:
- Does anyone who had this problem with a 2012 have a specific solution that worked for them?
- If I get stuck in the 50mph or idle mode does anyone know a way around the issue without begin towed to the dealer?
Thanks!
Thanks!
#156
JeffG5,
Please update us as to whether or not this software update fixes your problem and also if you notice any changes to the operation of the truck.
At around 1000 miles on the odometer, I had one exhaust fluid system fault that warned me that I would be limited to 50mph in 50 miles. It cleared within 10 miles or so of driving. I drove the truck for quite a while and then at around 1800 miles or so I had a warning that came up that I would be limited to 50mph at the next restart. After 2 restarts it did indeed limit me to 50mph but once again it cleared after about 5 miles of driving.
Both times I had planned to take the truck in to be repaired but the problems cleared up before I could. If this TSB is the cure, I plan to bring it down and have it applied to my truck as well. Good luck to you and I hope your truck is now 100%!
#158
Nothing negative to report so far.
#159
#160
Got my truck in to the shop today and they determined that TSB 12-06-05 was the answer to my problem. I now have the software update. BTW, they told me that P204F was the code that was retrieved. Noticed on the way home that the Exhaust system went through a cleaning cycle. Hope this fixes it, I was afraid to take it out of town!
#161
JeffG5,
JEFF
#162
Great news, great mileage towing. I get 9.5 towing 46 foot goose neck 17,000lbs.
#163
650 miles on my 2012 F350, 6.7L and got the DEF speed reduced error message. Message went away with 34 miles left to 50mph limit.
Question? Has anyone received this error code and then not received a DEF error code again? Or is it inevitable?
I am supposed to leave on Tuesday, towing my 12,000 toy hauler and because of the Labor Day holiday, I won't be able to get it into a dealership to have it checked out. Don't feel like getting stuck in the middle of nowhere driving 50mph or in limp mode either. Am I screwed or what?
#164
I just had the P2200 Exhaust Fluid Fault disappearing code. Speed was to be limited to 50 in 50 and cleared itself with 8 miles to go. Will it store the code and would the dealer reflash without a code? I don't know much about the dealers service techs as my last truck was an 06 150 with no problems. I did print out the IDS procedure to take along with me. Good or bad idea?? Don't want to seem like a know it all but don't want repeat trips to the dealer either. Truck is a 12 CC 4x4 with 2676miles and is AWESOME!!!!!!
#165
