HELP! What motors will Fit my 1964 E100 truck
I have an 1964 E100 pick-up. I bought it last spring the motor blow up in the summer. I was going to rebuild it but the block and the head can not be fixed. I bought another used 170 for it, it too was junk. I can't find a 170. What all motors will fit my truck with out cutting the floor or dog house? It is a 3 speed on the column, I want to keep it a 3 speed just like it is. I would like to change to a bigger motor but not sure what I can use. I found a guy with a inline 6 out of a 1964 f150 with the tranny and all . He said it was a 3.? i think it is a 240 if that sounds right would that fit in my truck? Thanks All for the info I'm new to this so sorry if I sound stupid.
AFAIK, there is no difference between a '64 and '65. IF that is true, and you will have to take the old tape measure to the scrappy unless someone else chimes in, then you can install a 240/300.
Some discussion here:
https://www.ford-trucks.com/forums/1...-econline.html
The 289/302 also fits with little work apparently.
FWIW, I would look for a 200.
Fordication
48
12-09-2013 12:05 AM
nlareau
11-16-2011 11:43 PM
72-F100-Shortbed
02-27-2005 10:22 AM
b1gr3d
33
10-17-2004 01:10 AM
74crwcb429hibPS4spd
09-22-2004 11:37 AM
