problems with new (to me ) truck
I bought a 2000 F/250 SD 7.3 turbo diesel about 3 months ago. Fixing little things here and there, rear leave springs,headlight switch, brakes.Nothing electrical or major mechanical. Was out running for parts yesterday and truck did great all day.
Was home for about an hour and went leave again and it wouldn't do anything.
Was like a completely dead battery except they arent. I turned the lights on and tried to crank it to see if it would draw the voltage down but it didn't. Wouldn't crank at all. Moved gear selector from park to neutral to see if that made a change, still nothing. Anyone have any ideas where to start so I'm not running in circles ?
I'm new to fords and to deisels so any help would be greatly apreciated.
Do you have any power at all? I was working on my 7.3 the other day and everything completely died, no power anywhere. It ended up being the main feed wire leading into the fuse box broke just behind the battery on the drivers sides. If you look behind it you'll see a wire coming from below the battery and a little box that says high voltage, it broke right there.
Thanks for the help and I'll keep updating as I go.
Thanks, Mike
did u have the batteries load tested? i know someone who has a 7.3 and it wouldnt start the other day. he thought it was the starter but turned out that one battery wasn't charged enough and it was enough to not crank. everything else worked with god power.
EDIT: Side note. It's possible the previous owner may have installed some sort of starter kill switch. When you were working on it previously...did you run across any non OEM looking switches or buttons? Perhaps you bumped a switch by accident?
Good luck.
James012
10-07-2022 07:23 PM
egrubb460
11-23-2013 12:07 PM
ROFLsplash
09-10-2010 08:51 PM
