Super duty rear axle into a OBS with 8 on 6.5 - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 03-08-2012, 01:55 PM
STIHL021's Avatar
STIHL021 STIHL021 is offline
STIHL021 is starting off with a positive reputation.
Got it was wondering that while I was reading the thread. Thanks.
  #47
Old 03-17-2012, 04:29 PM
Got4wd Got4wd is offline
Got4wd is starting off with a positive reputation.
All done except for the diff bolts. Assembly went together perfect. Now to get it in the truck. I'm going to use oem shock mounts that are welded on. I'm not a big fan of the other bolt on ones. But well see when it's in if I change my mind. Now on to my next project.
  #48
Old 03-17-2012, 08:07 PM
62uni4x4's Avatar
62uni4x4 62uni4x4 is offline
62uni4x4 is starting off with a positive reputation.
subscribed!
  #49
Old 03-19-2012, 06:57 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Man that looks awesome! I want disk brake rears!
  #50
Old 03-21-2012, 11:04 PM
TexasDiesel97 TexasDiesel97 is offline
TexasDiesel97 is starting off with a positive reputation.
I love that idea. How did you machine the SD hub to obs specs and not need extra holes? Sorry slightly challenged when it comes to machine work.
  #51
Old 03-22-2012, 09:14 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Quote:
He had the hubs machined out, then custom wheel studs made to fit the holes in the hub.
  #52
Old 03-22-2012, 09:35 AM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
Quote:
IIRC there are other bolt on disk brake setups for our current hubs?
Either way Im subscribing.. managed to skim through this thread, but none of the pictures show up on my work laptop
  #53
Old 03-22-2012, 10:23 AM
Thankyou Superduty, now I'm interested in the cost of those machined studs.
  #54
Old 03-22-2012, 10:31 AM
There are kits out there, but they all seem to have their flaws.
I'm wondering if you could get the SD rear axle and E-series hubs to save the machine work.
  #55
Old 03-22-2012, 10:33 AM
It seems to me that a SD rear with machined hubs or E-series hubs and a D60 front without the unit bearing style wheel bearings that they put on the SD trucks would be a great combination for a dependable running gear.
  #56
Old 03-22-2012, 11:54 AM
Dana 60 hubs (e series) and super duty hubs are totally different. If it was only that easy. I have looked at almost every single rear hub and couldnt find anything even close due to the super duty short spindle. But if someone can do it easier than I did, I would like to see it.
  #57
Old 03-22-2012, 01:14 PM
Quote:
Well crap.
So I'm curious... in your first post you have a hub with the hole pattern for both SD and OBS drilled into it. For most of us looking at this, shouldn't that be the route we go so that the custom machined studs aren't necessary? Drill 8 holes, install OBS wheel studs, assemble and go?
  #58
Old 03-22-2012, 09:56 PM
Quote:
Originally Posted by superduty4x4 View Post
Well crap.
That is exactly what I would do if you didn't want custom studs. I am still trying to find someone to make them reasonably. I do have another source in the works.
  #59
Old 03-22-2012, 10:30 PM
Fordworth's Avatar
Fordworth Fordworth is online now
Fordworth is starting off with a positive reputation.
Well crap.
I'm waiting on my machinist buddy to finish a pair of them for my '75 using this method. We are going about it a little different though. Instead of using regular pressed in studs he is going to tap the holes so I can install fully threaded bolts through the back of the hub flange. They will be held in place by green Loctite and wedge lock washers so they wont be backing out. The advantage is that the holes are smaller and there's less stress on the thin part of the flange since the studs aren't pressed in.
  #60
Old 03-22-2012, 11:26 PM
Quote:
So you are going between the holes instead of thru the oem holes right?
Obs 10.5 rear disc conversion hubs Got4wd Ford Truck Parts for Sale 1 11-11-2015 09:05 PM
Banks intercooler tee fitting question Got4wd 1994.5 - 1997 7.3L Power Stroke Diesel 1 05-19-2014 11:01 AM
Did I pay to much? SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-08-2012 10:24 AM
MY 96 CUSTOM HALF CAB PROJECT JERSEY MUD 1978 - 1996 Big Bronco 6 03-23-2011 12:23 PM
My new truck and Thank you!!!!!! Big-Sarge 6.7L Power Stroke Diesel 24 10-31-2010 07:46 AM
Tags
105, 1050, 1999, 302s, axle, boss, duty, end, ford, obs, rear, sterling, studs, super, superduty, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
