Super duty rear axle into a OBS with 8 on 6.5 - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-26-2012, 12:10 PM
Got4wd Got4wd is offline
Got4wd is starting off with a positive reputation.
Quote:
Originally Posted by MHammer21 View Post
Q... what is the real upgrade here? i am not familiar with the differences between SD and OBS hubs.
Thanks for the info.
Its also 3" wider
Old 01-26-2012, 01:46 PM
redman84's Avatar
redman84 redman84 is online now
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
I want to make sure I'm following correctly.
Sterling 10.5" from a SD? How about an Excursion too?
SD hubs? Any year or specific to some?
E series rotors? What years and can it be 250 or 350?
What for calipers, p brake, and pads?
Old 01-26-2012, 01:50 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
You use all the SD set up with redrilled hubs and rotors from I don't remember if it 98-99 van
Old 01-26-2012, 02:40 PM
Yes or a excursion. Anything from 99-04. I'm not a fan of the 99 axles because one caliper is front facing on the drivers side and rear facing on the pass side. Also it is a different housing compared to the 2000-2004. They use both rear facing calipers. But it's all preference. E rotors can be used from 98 or so up. I got mine from a 05 axle. If you went to a parts house and asked for a 2000 E rear rotor you would get the correct one. Semi or full float don't make a difference. Calipers, parking and pads all SD
Old 01-26-2012, 04:55 PM
MHammer21's Avatar
MHammer21 MHammer21 is offline
MHammer21 has a good reputation on FTE.MHammer21 has a good reputation on FTE.
what kind of cost are you looking at for the SD parts at a supplier?
Old 01-26-2012, 06:08 PM
I don't understand your question.
Old 01-26-2012, 06:24 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
remember guys, no buying or selling in the open forums.
i don't want anyone getting in trouble.
Old 01-27-2012, 12:27 AM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.joe_13894 is gaining momentum as a positive member of FTE.
If you're going ahead and drilling the rotors, why can't you just use the 9/16" stud?
Old 01-27-2012, 07:09 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
He didn't drill the rotors, just the hubs. And the 9/16 studs would be too big for the wheels and lug nuts.
Old 02-02-2012, 10:46 PM
Once the studs are coated ill press them in and post a picture.
Old 02-02-2012, 11:10 PM
As you can see in the picture, the very outside edge is the factory SD knurl.
Old 02-03-2012, 07:11 AM
Looks great! Keep the pics coming. Just curious though, if it worked well to just drill new holes and you don't think strength is a concern, why bother with this approach?
  #28
Old 02-03-2012, 10:39 AM
Quote:
Just cause this was was in the works months ago. Having the studs made took longer than expected. And I just wanted to see if my idea would work.
  #29
Old 02-03-2012, 11:17 AM
Got it. Looks really good.
  #30
Old 02-03-2012, 09:27 PM
Back from black oxide with oil dipped. I'll press them in and test fit them tomorrow.
Obs 10.5 rear disc conversion hubs Got4wd Ford Truck Parts for Sale 1 11-11-2015 10:05 PM
Did I pay to much? SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-08-2012 11:24 AM
Question About 79 Fair 96 1973 - 1979 F-100 & Larger F-Series Trucks 18 12-31-2011 01:20 AM
My new truck and Thank you!!!!!! Big-Sarge 6.7L Power Stroke Diesel 24 10-31-2010 08:46 AM
Fixed up my door panels mudder460 1973 - 1979 F-100 & Larger F-Series Trucks 28 03-31-2009 10:42 AM
Tags
105, 1050, 1999, 302s, axle, boss, duty, end, ford, obs, rear, sterling, studs, super, superduty, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
