You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
My current transmission (Ford E4OD) doesn't have bell mounts so I have to do side mounts.
I have to allow room for the "Rams-Horn" down pipes.
I like your project. I have a '57 that I'm trying to decide which to use; a mod motor/aod or a 292 I have, hooked to an aod. What bellhousing/adapter did you use?
I like the "Rams-Horns" too.
Steve
__________________
'56 F-100
'57 F-100
'54 Chev sedan del
'71 C-10
$349 is a fairly good deal considering that before they were available, some original (rusty, cracked) rams-horns went for over $600 on ebay from time to time!!!!
They're not cheap but it's the only game in town... I think I paid about $800+ for it. It does fit nicely but it requires you to go from the standard truck mounts to a side mount system and rear/trans-tailshaft mount.
I'm still building mine. I have some pictures which I'll post in a couple of days.
I chose an E4OD since they're used up to and including the F450 and behind the 300(6), 302, 5.4 V-8, V-10, 460, 7.3L Diesel, etc.....
Mine came out of an F-450 diesel. I had a transmission guy build me a trans using the trans-case from a SBF/300-6 using all the heavier duty parts for a diesel including the rear-mounted parking brake that came in the F-450 and motor home chassis' (The F-600 doesn't have parking brake provisions in the rear brakes)
I'll also add that I am sticking with the 292 because it'll look "right" under the hood and more importantly, It'll SOUND "RIGHT" too.
If I didn't use the Y-block, I would probably use an EFI 300-6
Regards,
Rick
__________________
1955 F-600/292Y/E4OD // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!!
1947 Stinson 108-2 Station Wagon, Franklin 6A-335B
1987 Four Winns 211 Liberator, 1997 Mercruiser 454/Bravo III
(RESISTANCE IS FUTILE) 73 de Rick
