1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
4 Pin Trailer Wiring
Old 01-25-2012, 08:46 PM
Eatonpcat's Avatar
Eatonpcat
Eatonpcat is offline
I have a 2010 F250 with the standard 4 pin and 7 pin trailer connectors. I just bought a trailer that I need to pick up that has a five pin connector. Is there any way I can adapt the 4 pin to accept the 5 pin??? I will permanently fix it and add a five pin in the spring, But I have to go a couple of hours to pickup the trailer empty and would like to do it without changing the factory harness (No need for trailer brakes).
Another question:
Standard Utility/Cargo trailer (12,500 gvrw), Truck is totally stock XL package, Do I need a drop hitch, If so, How much of a drop??
Thanks in advance for any advice!!!!
Old 01-25-2012, 10:00 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
What is the purpose of the 5th pin? I have heard that some trailers with surge brakes require the backup lights on the 5th pin to keep the brakes from activating when you're backing up. I don't know why, but that's what I heard.
I would make sure I knew what the 5th pin was for, then find the cheapest 7 to 5 pin adapter I could find. Or, buy a new 7 pin plug and put it on the trailer on the scene. You can do it with just a screwdriver, generally.
The hitch you will need will just depend on the trailer and the load. I'd get a pretty standard 2" drop for now and then see what you need later.
Old 01-25-2012, 10:06 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
I believe you can get a 7 to 5 pin adapter, no need to rewire anything.
As far as the hitch goes, it all depends on the height of the truck and the height of the trailer.
Old 01-25-2012, 11:32 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
5th prong usually is for brake release while backing up.
With my F450 I was backing up those with no 5th pin just fine.
Older trucks don't have backup light connected to the plug and I would have my doubts 2010 does.
Old 01-26-2012, 03:50 AM
1973Ford2004's Avatar
1973Ford2004
1973Ford2004 is offline
I have a 2" drop on my 2004 completely stock truck for my cargo trailer, I second the adapter 5 to 7
Old 01-26-2012, 05:32 AM
drey04's Avatar
drey04
drey04 is offline
Yep get the 7 to 5 adapter. My dad's boat has 5 pins, we just leave it attached to the trailer all the time.
Old 01-26-2012, 05:33 AM
Eatonpcat's Avatar
Eatonpcat
Thanks guys I will get the 7 to 5 pin adapter...Don't know why I didn't think of that, Somehow my head was wrapped around the four changing to 5.
Old 01-26-2012, 01:41 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
And again, make sure you have the backup light connected to 7 pins. Otherwise the adapter will do absolutely nothing.
Old 01-26-2012, 03:40 PM
dchamberlain
Ford trucks as early as 94 (my brothers) and 96 (my Dad's) had the 7 pin wired for backup lights. Every one I've seen since that had a 7 pin was wired the same. It's a standard and I'm sure they've done it since they put 7 pins on at the factory.
There was a period in early 2000 or around there where some towing relays and fuses were in a bag in the glove box, instead of in the fuse/relay boxes, but as far as I know, this was only a couple years.
Old 01-26-2012, 08:54 PM
Eatonpcat's Avatar
Eatonpcat
Bought the adapter (7 pin to 4 or 5 pin) today at Tractor supply, threw in the the ball also:
Buyers Adjustable Tri-Ball Mount, 12 in. vertical, 10,000 GTW
Out the door for a buck seventy!!
Old 01-26-2012, 10:28 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
Aren't you missing zeros before decimal point?
Evan adapter can be found cheap, the 10,000 hitches are not cheap.
How it works?
Old 01-27-2012, 04:10 AM
Eatonpcat's Avatar
Eatonpcat
How it works?
Not sure what you're saying...Here's a link.
The adapter was twenty.
add tax and you're out the door for 170!!!
Buyers Adjustable Tri-Ball Mount, 12 in. vertical, 10,000 GTW - 1004049 | Tractor Supply Company
gapman789
05-16-2017 07:41 PM
Bigpapa346
Electrical Systems/Wiring
04-25-2012 08:59 AM
fire3110
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-23-2009 08:30 PM
califordguy
08-30-2009 11:30 AM
tndiesel
11-03-2007 10:52 PM
Quick Reply: 4 Pin Trailer Wiring
