How did you body drop it? It looks like the stock frame rails under the cab, so I assume you must have done a traditional. I would like to see some pics of that and how much you body dropped it.
I cut 2.5" off the bottom of the frame and run a peace of 3x2 on the inside and boxed the frame front to back with a 94 chevy 1500 front clip under it.
Did you need to do any other modifications to the front clip to get ot to lay frame?
Also it looks like the clip is offset upward jusy about as much as you took off the bottom of the frame rails. was it nessessary to offset the front clip to keep correct camber while aired down?
