Skinny 35 or 36 inch tire?
Interco makes the SSR in a 35x10.50. Though I didn't have that size, I used to have a set of SSRs and they are a pretty nice tire. Much more aggressive than BFGs offroad, but about comparable in noise and handling on road.
Here's the link:
http://www.intercotire.com/tires.php?id=9&g=1
Here's the link:
4" lift & 35" tires on these things look PERFECT to me. Best stance/combo out there IMO.
Here's a few pics of different 35x12.5r15s on my '74 supercab with a 4" lift.
The black fenders are stock - white ones are autofab zero flare, 3" wider wheel opening ones.
Here's also one of the 315/75r16's on my crew cab. Being a '74 4wdF-250 it's a "high boy" so it's stock ride height is about 4" higher than a stock 2wd.
Gateway tire use to make a tall/skinny bias ply 36x10.50 "Buckshot mudder" that would mount up to a 6" wide steelie, they stopped production a few years ago, but there's still some old stock out there if you look.
(The new Buckshot mudder made by Maxxis is a poor imitation of the old Gateway version)
on
You could get a 255/85 r16 that is like a 33 or 34 and narrow. I ran a set of tsl Q78s and they were pretty awesome. I switched to a 35/10.50 bogger and those are unstoppable but noisy and little to no lateral stability. Bfg makes a new size, 295/75 r16 that might be pretty narrow and tall. I like super swampers. their radials get good mileage and they arequiet if you keep them rotated. You can go to a 10" wide in 35 or 36 or maybe even 37 in a ssr or a tls radial.
These guys were the last known outfit to still sell them, but now they're out of stock as well, may take some work to find a set.
Gateway Buckshot Mudder (Discontinued)
