Skinny 35 or 36 inch tire? - Ford Truck Enthusiasts Forums
Old 01-25-2012, 07:54 PM
White76 White76 is offline
White76 is starting off with a positive reputation.
Stupid question but does anyone know of a skinny 35 or 36 inch tire
Old 01-25-2012, 08:15 PM
twinzilla twinzilla is online now
twinzilla is starting off with a positive reputation.
These are 34's:
Narrow S.S. | Interco Tire
Old 01-25-2012, 08:54 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
how skinny is skinny? my 315/75r16 BFG ATs or 35x12.5r15 BFG AT's aren't super wide.
Old 01-25-2012, 09:21 PM
Ya I like the 35x12.5r15 BFG MT km2s and I will probobly end up buying them but I like the look of skinny tires. How do you guys think 35s will look on a f150 with a 6inch lift
Old 01-25-2012, 09:27 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
I run 35s with a 4-inch lift and the proportions look about right (Visit my garage). I think 35s would look "stilty" with a 6-inch.
$0.02.
Old 01-25-2012, 09:48 PM
crsweet78's Avatar
crsweet78 crsweet78 is offline
crsweet78 is gaining momentum as a positive member of FTE.
heres 35x12.5-17 on a 4" suspension 3" body lift. when I get a 6" lift Im definately getting bigger because it probably wont look right.
Old 01-25-2012, 10:11 PM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Interco makes the SSR in a 35x10.50. Though I didn't have that size, I used to have a set of SSRs and they are a pretty nice tire. Much more aggressive than BFGs offroad, but about comparable in noise and handling on road.
Here's the link:
http://www.intercotire.com/tires.php?id=9&g=1
Old 01-25-2012, 11:37 PM
BIGT94z's Avatar
BIGT94z BIGT94z is offline
BIGT94z is starting off with a positive reputation.
Powerking makes a great bias ply 9.00x16 which measures almost 36 inches
Old 01-25-2012, 11:40 PM
piperig78 piperig78 is offline
piperig78 is starting off with a positive reputation.
Use the above link and look at the TSL Bias plys the Q78-15LT measures 35.5 x 9.5 but it is bias ply
Old 01-26-2012, 12:56 PM
Quote:
They look GOOOOOD on a 4" and not bad on a 6". I'm much more of a "little list as possible/necessary" type guy, and I'm not a huge fan of overly agressive tire treads (or huge tire size) on trucks that won't use them.
4" lift & 35" tires on these things look PERFECT to me. Best stance/combo out there IMO.
Here's a few pics of different 35x12.5r15s on my '74 supercab with a 4" lift.
The black fenders are stock - white ones are autofab zero flare, 3" wider wheel opening ones.
Here's also one of the 315/75r16's on my crew cab. Being a '74 4wdF-250 it's a "high boy" so it's stock ride height is about 4" higher than a stock 2wd.
Old 01-26-2012, 04:12 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Gateway tire use to make a tall/skinny bias ply 36x10.50 "Buckshot mudder" that would mount up to a 6" wide steelie, they stopped production a few years ago, but there's still some old stock out there if you look.
(The new Buckshot mudder made by Maxxis is a poor imitation of the old Gateway version)
Old 01-26-2012, 04:54 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE F-250 WARHORSE is offline
F-250 WARHORSE is gaining momentum as a positive member of FTE.F-250 WARHORSE is gaining momentum as a positive member of FTE.
You could get a 255/85 r16 that is like a 33 or 34 and narrow. I ran a set of tsl Q78s and they were pretty awesome. I switched to a 35/10.50 bogger and those are unstoppable but noisy and little to no lateral stability. Bfg makes a new size, 295/75 r16 that might be pretty narrow and tall. I like super swampers. their radials get good mileage and they arequiet if you keep them rotated. You can go to a 10" wide in 35 or 36 or maybe even 37 in a ssr or a tls radial.
Old 01-26-2012, 07:10 PM
Hey if you come across any of those NOS Buckshot or Gumbo Mudder's I'd be interested in a link
Old 01-26-2012, 09:22 PM
Heyy Twinzilla, if you come across any of those NOS Buckshot or Gumbo Mudder's I'd be interested in a link also I going to look right know...
Old 01-26-2012, 11:45 PM
These guys were the last known outfit to still sell them, but now they're out of stock as well, may take some work to find a set.
Gateway Buckshot Mudder (Discontinued)
Tall/skinny tires for 1977 highboy? jwood65 1973 - 1979 F-100 & Larger F-Series Trucks 78 01-07-2017 09:25 PM
opinions about tires TheDevilsRightHand 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-15-2013 11:53 PM
35x11.5 Toyo Open Country M/Ts On 18s cdrmotorsports 1999 to 2016 Super Duty 22 09-18-2009 03:30 AM
Tall and Skinny tires for a Superduty Brian460 Brakes, Steering, Suspension, Tires, & Wheels 5 07-17-2009 11:26 PM
Where can i get skinny tall tires.. Big_Man_Brad Brakes, Steering, Suspension, Tires, & Wheels 1 07-15-2008 05:17 PM
Tags
16, 35, 900, bias, boy, buckshot, ford, gateway, inch, mudder, return, skinny, tall, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
