Abs control module replacement - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-25-2012, 06:10 PM
SuperMike SuperMike is offline
SuperMike is starting off with a positive reputation.
I am getting ready to replace my faulty abs control module. The service manual says to remove the HCU to replace the module. I want to know if there are any tricks to remove the module without having to disconnect the HCU so that I don't have to get the HCU bled.
Tonight I was look in the engine compartment and I was thinking that I could remove the driver side headlight and then cutting an access hole through the steel panel behind the headlight.
Any ideas??
2002 F250 spongy brakes, possible solution? cas17013 1999 to 2016 Super Duty 7 12-23-2016 05:32 PM
2006 Escape Hybrid ABS Problem wreckedcarz Escape & Escape Hybrid 1 09-19-2016 11:10 AM
High hopes!! Brake-bleeding question Christopher Turford 1987 - 1996 F150 & Larger F-Series Trucks 5 02-27-2016 03:57 PM
HCU antilock unit bleed 96f150 1997 - 2003 F150 0 06-21-2015 07:42 PM
HCU - wishfull thinking 96Broncowner 1978 - 1996 Big Bronco 11 04-07-2006 07:21 PM
Tags
03, 1999, 2005, 40, abs, aviator, computer, control, excape, ford, located, location, module, ranger, unit, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
