2003 Sd spark plug question
Im coming up on 100K on my 2003 5.4L SD. I called the dealer about changing the plugs which I know is a pain in the ***. He said the job was $400, but might be extra if the plugs snap off? My question. I know getting the plugs out are a problem but should I have to pay more because of that? Kind of an opinion question. I personally dont think it should be on me to pay additional cost. but that me.
Any suggestions or comments?
I agree with Redford and with JH. I changed mine at 105,000 and had no issues at all with plugs breaking. Just take your time loosening them and they'll come right out. The two worst plugs to get at were the passengers side rear. The drivers side rear was a bit difficult, but not as bad as those other two.
Also, I did not have to remove my fuel rail, but I did loosen it and move it out of the way a bit. Overall it was not a bad experience. About an 8 pack job or so.
why are you changing them at 100K?
Agreed. It's why I changed mine. My truck was still running fine, but after 105,000 miles, I figured it was time. My plugs didn't look that bad (see page 2 of this link: https://www.ford-trucks.com/forums/8...gas-smell.html). It seemed to run a little smoother, but for sure it just felt better.
Buy oem plugs and use dielectric grease. But don't use the grease like you are starring in a **** flick as it will cause you problems. A guy I work with was handing me stuff as I was doing a v-10 and he lubed it like a **** star and handed it to me. All I could say was Good lord and make him put down the dielectric grease and clean the coil boot off.
