Should I use the Tow/Haul feature? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-25-2012, 04:43 PM
Platinum Knight's Avatar
Platinum Knight Platinum Knight is offline
Platinum Knight is starting off with a positive reputation.
Just bought a 2010 F250 Super Duty Turbo Diesel last month with 7,500 miles on it. I plan on using it to haul a 18' tandem trailer max weight 5k lbs. With advice from a friend I added two up grades (SCT Livewire Flash Tool and a Bully Dog Cold air intake) to improve performance and fuel mileage.... My question is should I use the tow/haul feature or normal transmission. When I don't use the tow/haul my RPMs are around 1500 at 55mph and under 10 psi......With the tow/haul it stays around 2000 rpms and 10 psi.......I'm getting 14 mpg with the trailer and 24 mpg without with the upgrades.......Sorry if this is a stupid and long winded question...Newbie here...lol
<!-- / message -->
Old 01-25-2012, 04:57 PM
jlmotox's Avatar
jlmotox jlmotox is offline
jlmotox is gaining momentum as a positive member of FTE.jlmotox is gaining momentum as a positive member of FTE.
congrats on the new truck!! and welcome to FTE!
my opinion on tow mode is use it if the transmission is hunting for gears (keeps shifting) usually on hills this will happen. I also like to use it on downhills, makes holding a speed easier and less use of the brakes....with your trailer weight you could probably get away with not using the tow mode most of the time.
24mpg unloaded? you must drive downhill with a tail wind alot! lol
Old 01-25-2012, 06:47 PM
tgreening's Avatar
tgreening tgreening is offline
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Quote:
<!-- / message -->
This mileage is highly suspect. Are you relying on the dash display? While accurate enough stock (at least mine is) they are notoriously bogus when you have a tuner installed. Hand calculate is the only accurate way to do it when tuned.
Old 01-25-2012, 07:01 PM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
That trailer is next to nothing. Unless it hunts, leave the tranny alone.
Steve
Old 01-25-2012, 08:08 PM
Quad Racer's Avatar
Quad Racer Quad Racer is offline
Quad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to all
I usually only use mine when I run through the northern Kentucky rolling hills. Like stated earlier, the ups and downs of hills. My trailer is slightly heavier than yours and I have a V10 so she is a screamin 3.5-4k RPMs bout 8 MPG specially when JO's get you bogged down and take away my run at it.
Old 01-26-2012, 06:16 PM
Quote:
WOW I did as you suggested and was very disappointed with my results. Huge difference in the numbers...actually getting 13.1 with the trailer and I've not had the chance to calculate without.....So my dash read out is useless now???? bummer
Old 01-26-2012, 06:51 PM
Skinsfan6's Avatar
Skinsfan6 Skinsfan6 is offline
Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.
+1 Do not use tow/haul unless you are in and out of overdrive.
+1 Tuners screw up your overhead mpg readout. Prior to my tuner my readout was within 2 tenths almost every time. Now it usually displays about 2 mpg better than I am actually getting.
Someone Please Explain Tow/Haul DR Buck 1999 to 2016 Super Duty 27 10-16-2016 10:12 AM
Tow/Haul Question birdboy 1999 to 2016 Super Duty 32 04-25-2016 09:43 PM
Tow/Haul usage almostgone 1999 to 2016 Super Duty 11 03-16-2014 02:10 PM
tow/haul Patrick M 1999 to 2016 Super Duty 29 11-02-2013 01:18 PM
Use tow/haul or not with towing tune? DesMoinesDieselDuty 6.0L Power Stroke Diesel 8 04-25-2012 02:22 PM
Tags
appearce, bully, dog, duty, feature, ford, haul, info, mileage, performance, programmer, super, tow, towhaul, truck, tune
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
