Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Tennessee Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Tennessee Chapter Join Chapter Leader: Neal 97 250
  #1 (permalink)
Old 01-25-2012, 04:39 PM
Idahoser Idahoser is offline
2005 Ford F-250
Idahoser is gaining momentum as a positive member of FTE.
anybody near Memphis want to show off your Auto/Enginuity? [got one!]
I have codes that keep coming back. I'm probably going to buy one anyway, just thought a demo first might be a good idea.
__________________
2005 F-250 XLT SuperCab long bed 118k. ScanGauge II. 3X Fumoto's. Dieselsite filter. Delvac ELC. Rotella T6. Rev-X. Improved HFCM plug. Power Service every tank. 24" wipers. PIE. AutoEnginuity. Soon to install BPD EGR cooler, OEM oil cooler, STC kit, blue spring kit, NCHornet CCV.
  #2 (permalink)
Old 01-31-2012, 12:44 AM
Layed Out 100 Layed Out 100 is offline
Garage is empty, add now
Layed Out 100 is gaining momentum as a positive member of FTE.Layed Out 100 is gaining momentum as a positive member of FTE.
What codes is it showing?
__________________
Adam
05 F-250 4x4 Harley Davidson 6.0
57 Pontiac Supercheif
53 f100 My build thread http://www.ford-trucks.com/forums/97...ith-picts.html
  #3 (permalink)
Old 01-31-2012, 09:16 AM
2005 Ford F-250
the ScanGauge doesn't say what the codes are, only that the DTC count =3 at this point. I have ordered the AutoEnginuity but it hasn't arrived yet.
I did try Autozone and O'Reilly and their scanners both said no codes.
The last week or so I'd been having an increasing amount of blue/white smoke on start. It got to where it would take warming all the way over 190 before it would stop smoking, and sitting for a while even then on warm start it would smoke. But, it was intermittent. It DID stop smoking.
I changed my oil and oil & fuel filters Sunday. It smoked a bit Sunday and Monday, less than before, and there was none today. It's also been significantly warmer overnight than last week though, so there could be more things going on.
This is my second T6 oil change, I use Racor filters from DFO. 5,000 miles on the last three oil changes.
I also switched to the white bottle Diesel Fuel Supplement for this tank.
__________________
  #4 (permalink)
Old 02-03-2012, 05:06 AM
I live in hernando and work in memphis, I would not mind trying my SCT tuner to read it for you......I'm no mechanic but I do know a really good one for 6.0's in memphis and he is fast and cheap.
__________________
Adam
  #5 (permalink)
Old 02-03-2012, 08:59 AM
2005 Ford F-250
I appreciate the offer and I may like to see that in action in any case one of these days. But I did order the A/E and it should be arriving any day now so I think I'll be ok. The smoke did come back for a short time yesterday morning but none today, so I think the oil change did some good and the warmer weather does the most to help.
__________________
  #6 (permalink)
Old 02-17-2012, 01:06 PM
2005 Ford F-250
okay, after a shipping mixup I finally got my AutoEnginuity ScanTool a couple days ago. Yesterday I plugged it in and fooled around with it for a while. I can see many of the same things I can see with the ScanGauge II, although it is nice to be able to see many of them on one screen where the ScanGauge only does four at a time.
Now my smoking problem. I see where I can turn off individual injectors. Is that a good place to start? Or is there an 'injector test' I should run?
These are the codes I have now (there were four a week ago, but now there are only two)
- Enhanced Powertrain CAN
-- P0460 Fuel Level Sensor A Circuit
--- Module: Auxiliary Emission Controls
--- Status: MIL Pending, MIL Previously Set
(I have never seen the fuel low light, even though I've had it pretty low. The gauge works fine)
-- P0528 Fan Speed Sensor Circuit No Signal
--- Module: Vehicle Speed Idle Control And Auxiliary Inputs
(No idea about this one, I do get a reading on Fan Speed Sensor on the A/E and on the ScanGauge)
I wish I knew what the earlier ones were but, I guess, being "Pending" means they're historical, not current faults, right?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
