1965 f100 power steering help! - Ford Truck Enthusiasts Forums
Old 01-25-2012, 01:36 PM
1965f100123 1965f100123 is offline
1965f100123 is starting off with a positive reputation.
i have a 1965 f100 2wd and have read a few forums on this conversion, i got a power steering gear box from a 1975 f150 2wd, and i have a pump on the front of my motor from i believe a 1992 mustang, i have mounted the gear box and shortened my steering column, however i have just come across the fact that the shaft for the pitman arm is larger on this new gear box and the pitman arm for the 75 has a ball joint where the arm from the 65 does not, does anybody know what arm i need to get? i am hoping there's a car out there with the same size output shaft on the pitman arm and no ball joint on the other end so that i can use it on my 65 tie rods. any help is greatly appreciated thank you
Old 01-25-2012, 04:56 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
Old 01-25-2012, 05:04 PM
66f-100's Avatar
66f-100 66f-100 is offline
66f-100 is starting off with a positive reputation.
I think if you get the steering linkage from the '75, that will solve your problem.
Old 01-25-2012, 11:15 PM
jhooch's Avatar
jhooch jhooch is offline
jhooch is gaining momentum as a positive member of FTE.
Are you sure that the steering gear is out of an F150? It should have a non-serviceable pitman arm (no ball-joint). Did you pull the box from the donor? Something doesn't seem right here.
Old 01-26-2012, 07:56 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by 1965f100123 View Post
I got a power steering gear box from a 1975 f150 2wd, and I have a pump on the front of my motor from what I believe is a 1992 Mustang.
1965/77 P/S pumps have a steel reservoir. The P/S Pressure Hose threads onto the pump.
1978: Ford changed the P/S pump on everything except Econolines, has a plastic reservoir. This pump was used into the 1990's.
The P/S Pressure Hose has a straight tube on the pump end with an o-ring on it. It connects to the pump w/a qwik connect fitting.
Old 01-26-2012, 03:42 PM
whobock's Avatar
whobock whobock is offline
whobock is starting off with a positive reputation.
i just did the same conversion on my '65 last month. all of the aftermarket pitman arms that i found had the ball joint made into them. i tried an '80 pitman arm(no ball joint) and it fit(hooray!) but it was "clocked" wrong(ughh!) and wouldnt work. i asked the guy at the parts house why it had a ball joint made on it and no one could tell me.
i finally found one on ebay of all places from a 79 f150 with power steering and it worked. so i would say youre going to have to search and search for a salvage yard that has what your looking for.
now for bad news part 2. my truck also has a late model mustang pump on it. guess what? you are going to have to have the lines made.
i had to get a pressure line for a 75 and a pressure line for 92 mustang. then you find someone that can make lines have them cut the gear box end off the 75 and the pump end off the 92 and have them made into a new line. use the return line from the 75 cause you just clamp the other end on the ford pump. its not that big of a deal once you find someone to make the lines.
do you have the serpentine setup? are you running ac? i have the ac delete bracket and belt for the serpentine set up w/o ac if you need it(with the belt).
know thats not what you wanted to hear but hope that helps. im me or email me if you need more info. whobock@gmail.com ill help all i can. i wanted to pull my hair out before i figured it out so i know where youre at.
Old 01-28-2012, 06:35 PM
Chiefmech1's Avatar
Chiefmech1 Chiefmech1 is offline
Chiefmech1 is starting off with a positive reputation.
Power steering??? Don't need no stinkin' power steering...!
PS Install - Pitman arm question gofrogs69 1961 - 1966 F-100 & Larger F-Series Trucks 10 01-02-2013 02:52 PM
Toyota MANUAL Steering Box Pitman Arm Issue okedokeno 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 10-26-2012 11:45 PM
NEEDED: stock 78-79 f-150 p/s pitman arm lasthighboy WTB - Parts & other 3 07-02-2012 10:14 PM
1965 Steering Gear Box Removal F100-F250 F250GH 1961 - 1966 F-100 & Larger F-Series Trucks 0 09-16-2010 12:22 PM
74 2WD Manual Steering Pitman Arm dclary 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-04-2009 05:28 AM
Tags
100, 1965, 65, arm, box, conversion, f100, ford, gearbox, line, pitman, power, steering, thread, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
