"Check Engine" light comes on, on washboard roads.
On my 2003 V10, the more severe bouncy and washboarded roads often lights my "check engine" light. The truck runs as normal, the light will go off only after truck has been parked awhile. Does anybody have an idea which sensor or operation might be affected by washboard? Also, I remember somebody recommending a brand of weatherstrip lubricant to keep the squeeks away, in an earlier posting, any recommendations?
After the light goes off the code will stay in memory for 40 warm up cycles. A warm up cycle is when the engine is started with the coolant below 120F AND the engine warms above 160F before it is turned off.
For most people that means a code will stay in memory for three or four weeks.
