Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Engine Swaps
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 01-25-2012, 08:21 AM
SteveNCf250 SteveNCf250 is offline
Garage is empty, add now
SteveNCf250 is starting off with a positive reputation.
Ford Cummins tach ring
Hey all,
I am putting a 1996 Cummings 12v in a 2007 Superduty and I have a couple questions about the tachometer sensor. If I was to modify my harmonic balancer with 58 notches could I use the pulse sensor curnrently on the Cummings engine. I am trying to avoid bolting a pulse ring on the front of the balancer.
  #2 (permalink)
Old 01-25-2012, 11:45 PM
deck60's Avatar
deck60 deck60 is offline
deck60 is starting off with a positive reputation.
from my understang yes that would be correct
  #3 (permalink)
Old 01-26-2012, 06:39 AM
Deck60,
Thank you. Do you have a conversion?
  #4 (permalink)
Old 01-26-2012, 05:00 PM
deck60's Avatar
yes I do
99f350 crew srw
conversion 9812v nv4500 np273 converted to a manual
you have determined that you need 58 notches the dodge sensor is really simple
a couple of quotes
Quote:
Ohh yea I also ground two notches in the balancer for a total of four.
I just got mine figured out today.. U can use the crank or cam sensor from the v10. i used the cam sensor off of the ford v10 and made a bracket to hold the sensor. i tied one sensor wire into the dark green wire that was one of the wires that originaly attached to the cam sensor. the other sensor wire goes to ground. pulled the inner fender well on the drivers side and located the pcm plug and unbolted it. located the #85 wire that is dark green and located the #48 wire that is white with a pink stripe and cut them both and tied them together on the harness side not the pcm side. plugged and bolted the pcm plug. cranked the truck and walla a working tach. this was on a 99 f250 with a v10
dodge tach sense
#1 blk lt blue ground
#2 vio white 5 volt supply
#3 gry blk tach feed
  #5 (permalink)
Old 01-27-2012, 02:30 PM
Deck60,
Thanks for the info. Sorry it took do long to reply, it's been a crazy week.
  #6 (permalink)
Old 02-08-2012, 06:56 AM
redzcstandardhatch redzcstandardhatch is offline
redzcstandardhatch is starting off with a positive reputation.
Is this what id need to do with an 05 truck and 93 cummins? Interesting stuff
  #7 (permalink)
Old 02-09-2012, 06:08 PM
deck60's Avatar
yes 58 notches for the sensor to pick up there are a few other things also to do but the machining is the best no bolt on ring
  #8 (permalink)
Old 02-10-2012, 07:21 AM
Excellent. Thanks!
There isn't much step-by step stuff for putting that engine in my truck. Almost have all the parts!
Tags
1996, 54l, 58, balancer, cummins, duty, harmonic, inpot, modifying, pulses, sensor, supper, tach, tachometer, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
