easiest way to get 2" of lift?
Would this work on the front AND rear leaf springs?
http://www.jcwhitney.com/add-a-leaf-...=d51375y1973j1
1st off - what year truck is it? 78/79 F-250/350's are easier to lower the front leaf mounts on than the 73-773 ones.
Before I get into that though I'll answer the question above.
Yes an add-a-leaf can do it, but it will up your spring rate making your ride stiffer. As whistle1516 said - your calling a local spring shop & see what they can do. While they can re-arch them for you be warned that if they arch them more than the original/stock arch they will semi quickly sag back down.
I'd possibly look at the 2" lift pack BDS makes for the super-doodie/exursion. While I've read the SD leaf packs lift our old trucks higher than they do for the SDs - I'm not sure by how much.
As for the rear - I would run a different leaf pack rather than a 6" block, but that's me. If you don't use the truck for heavy hauling much a lift pack for a F series up to 96/97 (96 F-150, 97 F-250/350) can be used. Keep in mind these aftermarket leaf packs are typically for looks or off road use & not hauling a full load in the bed. They are softer for a better ride & more flex, not stiffer so you can haul a bed full of 90 lb. concrete bags back from homedepot.
On my '74 F-250 crew cab I wanted to compensate for the extra weight of the cummins in the front end which I have been told lowers the front about 1". To gain this inch back I lowered the leaf pivot points. I dropped the front one when I made this new cross member with hitch mount & recovery points. There are much easier ways to lower the points (searching here will pull up a few pics/ideas) but I was beefing up this area anyways so adding the 1" drop wasn't much more work.
It's not 100% done in this pic but you get the idea.
Next I made these shackles - they are 1" longer than stock. They're also stronger, lighter & look much cooler IMO
Last I took my stock springs to Deaver Spring (my local spring shop which happens to be well known & makes lots of lift & race leaf packs for many trucks) & had Jeff check the arch on them & put them back to spec if need be. Turns out they had sagged about a 1/2" so he put them back in spec. I also had him add the teflon slider pads between the leafs. They drill each leaf & put in little pads/sliders like in the pic below (internet pic - not my leafs). These pads help soften up the ride a lot. I also had the guys put new bushings in the springs while they had them.
StangLX302
18
01-09-2008 12:03 PM
