Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-24-2012, 06:26 PM
cheese4420 cheese4420 is offline
Garage is empty, add now
cheese4420 is starting off with a positive reputation.
HVAC door flapping
I'm hearing what sounds like a door flapping coming from the very center of my dashboard. The outside temp was 68 and the internal temp was set to 68. I did not have the AC running and had it on face/floor blend with the fan on the lowest setting. My wife was driving and what seemed to be random times there was a flapping sound coming from the dash. It sounded like a plastic flap or door was bouncing or flapping like a screen door flapping open and closed on a windy day. I switched the vent to just face and it continued. I then switched the air completely off and the flapping still continued. This just started happening and I'm not sure what it could be. Does anyone have any suggestions? I would like an idea before I take it in to the dealer because since it does not happen on cue, it is more difficult to reproduce, diagnose and repair.
Thanks!
2012 Expedition Limited, 4wd.
  #2 (permalink)
Old 01-25-2012, 11:11 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
It sounds like the blend door is broken. Does it happen when you turn on/off the recirculation button?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 01-25-2012, 02:46 PM
cstanley44's Avatar
cstanley44 cstanley44 is offline
2008 Ford Expedition
cstanley44 is gaining momentum as a positive member of FTE.
If its like whats in my Explorer the recirc door and blend door are different doors.
The blend door blends hot and cold air
The recirc door opens and closes outside air
Ive had the recirc door replaced under warranty in my 04 explorer, a $49 part, and $700 labor! Its broken again, but not under warranty so I just removed the door.
__________________
Curtis
2008 Expedition EL Limited
2004 Explorer XLT 4x4 4.6
1970 Buick GS 455 Silver Mist
  #4 (permalink)
Old 01-25-2012, 02:52 PM
berry1234's Avatar
cstanley is right. The recirc door lets air in from the outside. See if operating this makes the noise go away.
__________________
  #5 (permalink)
Old 11-11-2012, 06:22 PM
Well, it's broken again. Maybe this time they won't scratch the dash up when they replace it. Any idea how to keep this thing from breaking? Leave system on or turn it off? Has anyone else had this problem on the newer model Expeditions? I've seen posts on models which are five years old but nothing on the new models?
  #6 (permalink)
Old 02-01-2013, 03:48 PM
Craig.Parks's Avatar
Craig.Parks Craig.Parks is offline
2004 Ford F-250
Craig.Parks is starting off with a positive reputation.
cheese4420,
This has just started occurring in my 2009 Expedition. It seems to happen when temp is turned down to 60. Where you able to get yours fixed?
Thanks,
Craig
__________________
Craig
________________________
'04 F250 XLT 4wd 6.0 08/03 build, Fumotos, HFCM plug, Blue Spring, Coolant Filter, ELC,
Bak-Flip tonneau, Upfitters, Dvd, 12" Sub
  #7 (permalink)
Old 02-15-2013, 08:18 PM
I've gotten mine done at the dealership as it was covered under the warranty. After really pressing my service manager, he said the only recommendation he had was to keep it out of the sun when parked. He said the extra heat causes the grease to rout of the gears and they strip out. I just moved from Phoenix to Chicago and when switching from AC to heat in the rear, the rear controller went out. What top notch engineering is all I can say about all of it.
  #8 (permalink)
Old 02-18-2013, 08:06 AM
2004 Ford F-250
Yep, I had to replace the rear controller in our '05. You would think they could fix the issue by now.
__________________
Craig
Tags
2007, 2008, ac, blend, dashboard, door, expedition, flapping, ford, hvac, mix, noise, recirulation, taurus, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
