VIN dash tag - Ford Truck Enthusiasts Forums
New Hampshire Chapter Join Chapter Leader: 7283-F250
VIN dash tag
Old 01-24-2012, 05:46 PM
4x484150's Avatar
4x484150 4x484150 is offline
4x484150 has a good reputation on FTE.4x484150 has a good reputation on FTE.
VIN dash tag
I have an 84 F150. If I were to say, get an F250 of the same generation with a rotten cab, but wanted to swap the cabs, could I put the 250 Vin tag in the 150 cab? Paper work is in the picture, I'd imagine. Thanks in advance!
Old 02-02-2012, 07:23 PM
7283-F250's Avatar
7283-F250 7283-F250 is offline
7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all
I did the opposite.
Put a F150 cab on my '83 F250.
I called the state and had a new vin created. A state trooper came to the house and checked it out and put a NH VIN on it. It was a bunch of years ago so I forget all the steps. But technically and legally that is what needs to be done.
But what you actually do is up to you. Remember if you use the F250 tag you will be paying more in registration because on the books the F250 hold more and weighs more than the F150.
Cab swap, what to do about VIN tag? bulletsneverlie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 07-01-2015 09:34 AM
Vin location 1978 F150 alex211 1973 - 1979 F-100 & Larger F-Series Trucks 17 10-31-2014 09:28 AM
VIN Tag Decode-Help,,, Please... xgkrx 1961 - 1966 F-100 & Larger F-Series Trucks 12 06-07-2013 02:40 PM
VIN Tags oldjag 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-30-2007 04:37 AM
VIN location ncl 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-09-2003 09:34 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
vindash, wwwru
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
